that clutch line will work fine. from memory the slave is a pretty std rhs style slave. so you could try hilux, t18 or even jdm ae86.
i think aus delivered IS200 has the slave on the opp side as 1G's flow the other way.![]()
Car - AE86
motor - 3SGE Beams and 6 speed
use - fills my carport up
problem - need a clutch slave
I need a clutch slave for my 3SGE Beams J160 6 speed gearbox. Ive just searched for 3 hours and I cant find shit. Then again im probably not asking the right questions. And from what i can rear, some people are saying that different toyota slaves will bolt up and work fine.
My question is... do I have to use a legit 3SGE Beams 6 speed slave.... or will another model fit. If I must use the 6 speed slave, where can i find one online? As Im finding there arent enough hours in the day to get everything done ATM. And If I dont find one, i wont make the annual. Ill try ringing toyota tomorrow during the day.
And what clutch line will i need? I currently have a OEM 86 clutch slave and a braided clutch line.
Also, does anyone know what size the fitting is that the AE86 clutch master reservoir screws into? As I need to make up a new linee for a remote resevoir.
Cheers.
Thanks Anthony...
This is what made me wonder about using different slaves...
"The J160 is the 6 speed as used in the SXE10/GXE10 Altezza and was supplied to Toyota by Aisin (AZ6) and is the same gearbox used by the Mazda MX5/Miata, Mazda RX8 and Nissan S15"
So im wondering if a slave off of one of them will fit, but it might/most probably will have a different clutch line? Should be fairly easy to get hold of one of them...
It also seems that the J160 slave is a much larger bore than others... 15/16 apparently.
i can more then likely line one up from toyota nz as that is were i get all my beams parts as toyota australia are hopeless when it comes to japanese motors.
They see me rolling..... They hatin
I can actually get them right here in SA thanks to CMI Toyota... but I need to figure out if I need Pre or Post may 2000, and they're 3 weeks ex japan> So I wont make the annual.
just use a ra40 series or 60 series same dia slave and will work ok
will my 86 line screw into it?
And Im using an exedy hyper-metal super single, wont be too much? I guess I can use it to get me through the annual and swap it out after?
When I had a 6 speed laying around I compared it's slave to my AE86 one and it appeared pretty much identical.
Andrew
Thanks for all your help guys.... got it all sussed, will haveit's clutch stuff completed on saturday!
