Lots of misc parts lying around need them gone make an offer will also swap for s14 coilovers,s14 manual ecu,electronic boost controller
SSR Center Caps $80
T28 ball bearing with snorkel blown rear oil seal $250 no wastgate actuator
*ke70/ae71/ae86*
x4 ke70 Doors all been rubbed back minor surface rust no fitted with laser cut aluminium door trims sprayed black they look sick from the inside the $100 a pair $180 for the lot
Toyota Boss Kit $40
Ae71 alloy stockies $100 for the set
complete front xmember with control arms steering arms and rack $120 will not seperate
ra40 adjustable tie rod ends straight bolt on to ke70 steering arms as seen in pics next to stock ones $50
Stock tie rod ends $30
ke70 rear handbrake cables very good nick not stretched $50
Rear shocks $50
Chopped rear springs $20
tailshaft to suit 4k $40
4K starter Motor and alternator $80 for the pair $50 each
Nissan parts
CA18DET Nis-tune chip + ecu combo tunned for z32 afm,gtr injectors,t28 bb turbo and 18 psi boost never been used comes with tunning cable and all instructions i highly recommend these ecus as they retain all factory features however are fully adjustable $350
GTR injectors 444cc cleaned and flow tested a month ago good working order perfect upgrade for ca18 $180 or $195 posted will swap for s15 injectors
CA18 WIRING HARNESS complete with afm,ignitor and drop in resistor $120
T28 stainless split dump pipe $60 very little use “dump pipe only”
S14 n/a distributor + chopped loom $50
castor arms they have polyurethane bushes all in good working order $50 per arm $80 pair
s13 silvia roof lining immaculate condition- $80
S13 steering column with original key- $50
180 sx seats abit worn dhs reclining mecanism abit lose still work well- $40
sr box 2nd gear blown has ca front bellhousing on it ATM box alone $80 bell housing $50 $120 complete
SR20DE flywheel $50 has been machined ready to go
180sx indicator stalk $40 good working condition
r180 diff- $50
contact nicko 0412400500 located in sydney sutherland shire as stated earlier will swap for s14 parts (coilovers,s14 manual sr20det ecu, electronic boost controller)
