Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Wilwood brake kits
    Jul 2010
    awesome!
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    by my calculations an S13 one is very close, but the rotor offset is wrong i think.
    the ones in the kit are very dissapointing
    Andy
    Veteran Touge Boy's Avatar
    Modbury
    The ones we're going to be using are exact size, right offset, just the centre bore is a smaller, so will have to be bored out and the right pattern drilled for the hub. We're going to try and get hold of blank rotors first.
    Andy
    Adelaide Hills
    2 piece rotor?
    would be keen on some
    Andy
    Jul 2010
    what model are the from? im up for replacementes very soon
    i can bore out easily myself too
    Modbury
    Nope, Single Piece. I dont want to reveal any more until we've had a set done and Im certain they work on my car ok. Dont want to tell people they'll work and they're shit haha. The PCD for the hub will have to be filled and re-drilled too, but the holes for the studs will be ok as they're a 5 stud rotor and they can be redrilled to suit 4x114.3.
    Ill probably pick up a set from a wrecker first and get them machined up @ Work, and then go from there, hoping to locate a pair sometime next week and will be posting my results.
    Andy
    Adelaide Hills
    Seeing you've sold your car now, care to let us know what they are off?
    would like to know so i can get some spares!
    PM if you like
    Andy
    Jul 2010
    Mat
    Christchurch
    Sydenham
    New Zealand
    we always use old prosche brembos like off a 924 with audi rotors on the osca cars (sr20det 4agte 3sgte) and they worked fine they where cheap to we used to get them for 200nzd a set and the discs where dirt cheap too then all you had to do was make a bracket
    Senior Member Dongaz's Avatar
    Cameron
    The Gap, Brisbane
    Still able to get them or know what the part details are to get them?
    Would be interesting to see what difference they work out to be compared to a set of the wilwoods.
    How much are the wilwoods for a pair anyways?
  1. Replies: 31
    Last Post: 8th April 2014, 12:38 PM
  2. Wilwood big brake kit clearance
    By DR86FT in forum Technical - Questions
    Last Post: 7th November 2012, 11:41 PM
  3. wilwood brake bias ajuster
    By ae86-13b in forum Cars or Parts Wanted
    Last Post: 11th August 2011, 10:35 AM
  4. WILWOOD Brake kit
    By myt-16v in forum Technical - Questions
    Last Post: 1st November 2007, 12:11 PM
