Results 1 to 4 of 4
Thread: clutch slave JDM???
    Member ONCHRG's Avatar
    Jun 2009
    Wyndham Vale
    Default clutch slave JDM???
    Car - AE86
    motor - 20v
    use - bit of this and a bit of that
    problem - changed over to JDM bellhousing so that the clutch line is away from the exhaust but now the ADM clutch slave cylinder doesnt fit because the inlet line hits the bellhousing. (even if it didn't hit the pin that pushes the clutch fork wouldn't line up)
    occurs/started when - i changed the bellhousing
    personal situation - want the part number preferably of the JDM CLUTCH SLAVE.
    Thanks
    Ok
    Seamus
    Milton
    Someone will need to confirm this, but an identical slave (that's cheap and easy to locate from local repco/supershit etc) to the JDM slave is a T18 one?
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    I think I used an ra60 celica one.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    RaY
    Got a T-18 one from repco, looks identical to the Ae86 one but with the mount on the other side.
  1. jdm clutch slave
    By kronix in forum Technical - Questions
    Last Post: 23rd May 2011, 05:53 PM
  2. WTB or swap for a T50 JDM clutch slave cylinder
    By Plelz in forum Cars or Parts Wanted
    Last Post: 12th February 2011, 10:16 PM
  3. jdm clutch slave
    By haveaparty in forum Car Parts For Sale
    Last Post: 19th July 2010, 11:02 AM
  4. wtb JDM clutch slave
    By Adsport in forum Cars or Parts Wanted
    Last Post: 4th August 2008, 09:23 PM
  5. JDM bellhousing / JDM clutch folk and slave cylinder?
    By oae 86 in forum Technical - Questions
    Last Post: 17th December 2006, 03:49 PM
