Results 1 to 10 of 10
Thread: beams not starting twice with same battery????
    Jul 2010
    Default beams not starting twice with same battery????
    car: ae86
    engine: beams 3sge running with adaptronic
    ive got a pretty weird problem with my motor
    ive just got it running and cant get it to start a twice
    the story goes like this:
    if i start the car with a fully charged battery it will start up first pop and run. now if you try to start the car again it will not start! all it does is backfire out the throttles. now if you swap the battery it will start up fine? ive tryed disconnecting the battery and hooking up it back up and wont start with that same battery!
    whats going on? has anyone ever heard of this?
    Veteran blair's Avatar
    Blair
    SEQ
    Dead/incorrectly hooked up alternator?
    like if it only just has enough oomph to start once, then not charging whilst running.. so then it doesnt have enough for second round?
    Veteran biggo's Avatar
    Nick
    Noosa
    check battery earth on motor?
    Jul 2010
    yep everythings earthed
    im thinking ecu now
    Senior Member dtour's Avatar
    Jun 2009
    Jon
    Ryde
    have u updated the firmware for the adaptronic?
    i had a similar problem where i would turn the car off come back to start it and all it would do is crank and misfire.
    changed the battery and upgraded firmware and was all good
    User fantapants's Avatar
    Pat
    this.
    either a poor connection is causing some sort of reset? or the ecu is playin silly buggers...
    06/07/2011
    Jul 2010
    yep noted will load latest firmware on tomorrow when i can get ahold of a cable
    the computers run off a relay all 12+ connections look good. how does the ecu earth?
    tryed new plugs today they were for a caldina though....... it just pops bigger flames out now....
    Jun 2009
    Jon
    Ryde
    make sure u reload the fuel and ignition maps too
    Nick
    Noosa
    if its popping flames that means you have fuel and spark. Ergo, your timing is retarded ALOT, could be the ecu not knowing where a reset is or a knock sensor retarding timing or something like that.
    Jul 2010
    what is the knock sensor and where will i find it?
  1. WTB: 3tc Battery tray and 3TC battery hold down
    By kul_blu_car in forum Cars or Parts Wanted
    Last Post: 18th February 2011, 06:34 AM
  2. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  3. 4ac not starting...
    By squish_m8 in forum Technical - Questions
    Last Post: 18th July 2010, 10:47 PM
  4. starting issues...
    By dori_86 in forum Technical - Questions
    Last Post: 14th November 2009, 12:40 PM
  5. still have this starting problem
    By deanoo in forum Technical - Questions
    Last Post: 9th January 2007, 10:09 PM
