you cant talk blair im sure you used to run 6.5J not too long ago!
should be fine but just keep in mind of a bearing failure. also wheels studs are put under a bit more stress. the actual wheels should be fine.
i was going to do this on my car at one stage but it was a little too much offset for the guards so i went normal side up and used spacers instead.
