Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Flipped meshies
  1. #21
    Aaron
    In the Mountains
    i didnt use them like that, note only 1 nut was on in the photo. took them off, put them back to normal and used spacers.
  2. #22
    Veteran AJPS's Avatar
    Lonsdale
    thats another point too
    But the more the wheel sits out front the hub the greater leverage it has..
    I went from -4 offset to 0 offset and there was noticeably less bump steer and it more compliant mid corner.
    Brakes can increase the effect as well. Heavy brakes on the end of a strut can work like a slide hammer with a big weight on it
  3. #23
    Dave
    leverage affects your "percieved" spring rate, i guess you would call it.
    if we are going to get technical, its the change in moment on the spring (moment = force x distance, distance is changing)
    if your wheel sticks out futher your springs will "seem" to be softer, since like you say, the greater leverage on the springs.
    but this is not changing bump steer.
    what you will be changing is the amount of travel your suspension will be using, and if you go within the bump steer range, then i guess you will experience more. but thats a secondary effect of the lower offset wheel. its not creating MORE bump steer, your just going to experince the bumpsteer if you enter the "bump steer range" in teh suspension travel.
    also im not sure you would notice a 4mm change in length of lever arm, over a length of 500mm? perhaps more?
    in fact you would notice more compliance in the suspension if you made your wheel more negative offset (Stick out more) since the lever arm is being increased. (i think you are describing the opposite of this?)
    - Blaise Pascal
  4. #24
    Moderator Sam-Q's Avatar
    Endeavour Hills
    all the comments about extra load and a unwanted change in the scrub radius is true but flipped wheels can not be critised for this any more than the negative offset wheels which are so popular on here.
    Also I think an extra valve hole could be drilled, sure it would be kooky having 2 valve holes but who would know?
  5. #25
    alex
    Inner West Lad
    hahaha guys guys, relax, i picked up a the pair for $55 so i cant complain .. they do stick wayyyyyyyyy out of the front guards and i really wanna run them up front, do you think it would be smarter to run them on the front or rear??
  6. #26
    Aaron
    In the Mountains
    put them back to normal and use spacers so you dont have to fuck the guards up.
  7. #27
    alex
    Inner West Lad
    dont give a fuck about the guards, more concerned about bearings etc
  1. AE71 Stationwagon, 1.6, flipped springs, needs work - TAS
    By Skid_KE70 in forum Cars for Sale (Toyota Only)
    Last Post: 8th August 2010, 01:27 PM
  2. SSR Flipped meshies/ Cusco AE/KE strut brace
    By SR AE86 in forum Car Parts For Sale
    Last Post: 29th August 2009, 08:32 AM
  3. meshies
    By Roo. in forum Car Parts For Sale
    Last Post: 26th January 2009, 09:31 AM
  4. Pair SSR 15x7 FLIPPED meshies
    By PHAT86 in forum Car Parts For Sale
    Last Post: 9th July 2008, 10:23 AM
  5. meshies and some others
    By roger roger in forum Car Parts For Sale
    Last Post: 6th March 2007, 06:07 AM
