Results 1 to 4 of 4
Thread: clutch issues?
    Jul 2010
    BK
    Melb
    Default clutch issues?
    I have been experiencing stalling issues with my car and im not sure if its a clutch problem or not, but i get a feeling its related somehow.
    when i let off the clutch to the friction point, instead of moving the car like it should it will stall instead, and even if the gear engages properly there is alot of chatter.
    anyone got any clues as to whats wrong?
    Site Supporter Javal's Avatar
    Josho
    You're going to require a more descriptive and well thought out explanation of your problem if you wish to yield a constructive answer.
    At the moment all you're going to get is a lot of people either saying 'shit dawg iz it a puk clutch cause dem can be trublsum' or 'lern2driveLOL'
    Jason
    Gold Coast
    yeah more description.
    Also when you put together a sentence don't just keep going from one point of discussion to the next with no stops or commas if you include a comma after each point you make people reading it will understand that your moving onto the next point of discussion.
    eg. Also when you put together a sentence, don't just keep going from one point of discussion to the next with no stops or commas. If you include a comma after each point you make, people reading it will understand that your moving onto the next point of discussion.
    See how much easier that is to read ^^^^^^
    Jul 2010
    BK
    Melb
    ok thats fair, theres too much that could be wrong so ill update if i get some better info.
    the clunking I belive might be the tranny mounts but ill have to check if its loose or not, but im just not sure about the engaging issues.
  1. clutch pedal/ gearbox maybe clutch plate issues
    Last Post: 28th January 2012, 12:28 PM
  2. clutch issues
    By benno93 in forum Technical - Questions
    Last Post: 6th August 2010, 03:37 PM
  3. clutch issues
    By .ady in forum Technical - Questions
    Last Post: 17th September 2009, 10:24 AM
  4. Clutch issues
    By sprint86 in forum Technical - Questions
    Last Post: 20th August 2009, 09:04 PM
  5. clutch issues?
    By johl in forum Technical - Questions
    Last Post: 12th September 2007, 03:00 PM
