Results 1 to 3 of 3
Thread: fuel cells
    Apr 2010
    Troy
    Wodonga
    Default fuel cells
    Hey im looking at running a fuel cell in my drift car as the boot floor is non existent due to rust and the fuel tank will probably fall out as well soon, just wondering if it has been done before? and any recommendations on what sort, poly or ally, and what size for a 1.6l turbo engine for track days, foam or no foam. Also anywhere that sell them in S.A.
    Does anyone else run them are they good?
    I have found a few on ebay and i know they are pricey.
    Veteran slydar's Avatar
    Dimitri
    i bought mine from vpw. i used foam filled poly, faced the pick up towards the rear and got away with using no surge tank that way. mine was about 30L which was heaps even for street driving, though my car was NA.
    appazza the foam can break down eventually and block the fuel pump.. but i think that takes years, i.e heaps longer than the life of most well modded drift ae86s.
    78's
    Gunner
    Something to keep in mind, some of the foams used are not alcohol safe, and using ethanol blended fuels may cause them to perish aot quicker, and as Slydar said it will block pumps.
  1. Replies: 3
    Last Post: 13th April 2012, 03:11 PM
  2. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  3. fuel rail adaptor plate for aftermarket fuel pressure reg
    By 1sik20valve in forum Cars or Parts Wanted
    Last Post: 5th January 2010, 02:18 PM
  4. Fuel Cells
    By Magic School Bus in forum Technical - Questions
    Last Post: 30th January 2009, 04:00 PM
  5. 4AGE losing fuel supply round corners & when low fuel in tank
    By Sidey in forum Technical - Questions
    Last Post: 11th April 2008, 05:41 PM
