WIll be fitting the huge water tank out of an RA wrx, and will run a custom spray bar (modified cry 02 spray bar) triggered by a hob switch to come on at 12psi, will be sprayed through a new hyperflow top mount.
if its just for the drag strip, can use water to air intercooler and plumb the heat exchanger in passenger footwell into a tub filled with dry ice, will keep temps down, otherwise just put a water/alcohol spray onto the intercooler when it gets too hot - try the common fixes first i say
still on a/c drama in mirage? find the a/c on signal coming from the switch, remember might go through fan speed switch first cause u dont want ur a/c on with no fan or ur evaporator will ice up quick like, run that through factory thermostat and pressure switches to compressor, whenever a/c button is on and evaporator not iced and not low pressure and not high pressure a/c will be on, all through rev range
