Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 31 to 40 of 85
Thread: HOW TO: 4AGE into ADM AE86/AE71 Wiring guide
  1. #31
    Dec 2011
    Kerry
    Warradale
    im not entirely sure what loom it is...it came with the motor, i have a feeling that its a fwd loom though
  2. #32
    Yeah in the small port loom it is red/black and red/blue for the reverse lights... The red/blue has constant ignition power and it switches to red/black when in reverse.
  3. #33
    Dec 2011
    Kerry
    Warradale
    cool, cheers!
    i will no doubt have more questions later as i start to piece it all back together!
  4. #34
    Dec 2011
    Kerry
    Warradale
    so now i have another question...
    speaking about the connector on the firewall...that joins to the standard loom, 6 pin black plug
    the engine side loom is only a 4 pin plug...with the two center wires not running through the plug...
    the wires are black with red trac, and black with orange trace...any idea what these two are?
    can provide a pic of location for reference if required
  5. #35
    Post up a pic, but most likely it is something that has been added by the person who wired it previously to get power from one side of the bay to the other or the tacho signal etc.
    For the ke70 the following goes through
    Reverse Lights - 2 Pins
    Oil Pressure Warning - 1 Pin
    Temp Gauge - 1 Pin
  6. #36
    Dec 2011
    Kerry
    Warradale
    ok...heres a pic of the connector that im talking about
    and heres one of the wires in question
    it looks like they have been pulled out of the plug and were running through two inline fuses going somewhere
  7. #37
    Dec 2011
    Kerry
    Warradale
    there are 3 wires there, it the 2 that are joined together that im not sure about...black with red trace, black with orange trace
    the third wire black with orange rings im unsure about also
  8. #38
    Smallport loom right???
    Black / orange is the power input for your injectors / coil...
    Black / red will most likely feed power to the FOC relay inside the cabin
    Factory setup for the ae92 smallport has 2x black / red trace wires.. The thicker of the 2 has constant power and the thinner plugs into the output of the efi relay and powers up your B+ to the ecu and also the fuel pump relay.
    It's ran across the bay because in the ke you grab coil power from the drivers side. The ae71 i've got has the coil power on the passenger side, but this could have been changed by the person i got it from.
    The black wire at a guess i'd say is tacho, basing that on the coil location on the ke70, but trace it out with a multimeter first.
  9. #39
    Dec 2011
    Kerry
    Warradale
    its a bigport loom
    ill have a sus and see what they went to on the old car i removed it all from
  10. #40
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Hey guys, back again, pretty sure my injectors arent clicking, is EFI main relay 2 required to run them?
  1. 4age in ADM 86 won't start. Wiring?
    By genkin in forum Technical - Questions
    Last Post: 31st December 2012, 09:27 AM
  2. plug and play wiring loom - 4age to ADM ae86
    By StuC in forum General Topics (No Technical Questions)
    Last Post: 13th April 2011, 09:52 AM
  3. 4age bigport wiring in to adm ae86 need help asap
    By fat_ke in forum Technical - Questions
    Last Post: 18th September 2010, 07:52 AM
  4. wiring up 4age into adm 86
    By driftnick13 in forum Technical - Questions
    Last Post: 2nd January 2010, 05:00 PM
  5. Trev's Guide To Repairing 4age Dizzy Wiring
    By Trev084 in forum Technical - Articles
    Last Post: 25th August 2008, 09:04 PM
