Results 1 to 3 of 3
Thread: 4age quad carbies
    Aaron
    Salisbury east
    Default 4age quad carbies
    hey guys,
    im keen of doing a quad carby for the 4a, cant find much info. anyone got any links? how do i determine the runner lengh? what are a good brand of bike carbies? what would be a good size, i have heard carbies off a 1000cc. i heard for the best power gain is to run the carbies out of a plenum, then i guess run a cold air intake. that is what i would like to tackle for my daliy drive.
    any imput would be great!! cheers guys!
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    This has been covered before, but I'm guessing it's hard to find.
    If you have the cashmoney, do keihin FCR's, or MSR's.
    Slide throttles are what you want, most sportbikes have them.
    1000cc would be a little bit too big, depending on what other work you're doing to your engine. 750cc is probably better for something with mild cams, high compression etc.
    You will need to do the normal things when converting to carb such as modifying a 4k-c dizzy to work, etc etc. It's pretty straightforward, has been covered before.
    For ideas on a plenum, cold air would be a plus, as well as limiting the amount of turbulence the air has before entering the runners.
    Cool vid:
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
    Aaron
    In the Mountains
  1. 4age 16v small port head 4age dizzy for carbies
    By dehney in forum Car Parts For Sale
    Last Post: 2nd November 2010, 07:15 PM
  2. 4age carbies ?
    By aussyboyz in forum Technical - Questions
    Last Post: 26th May 2009, 10:04 PM
  3. FCR's carbies on 16 4age
    By dehney in forum Technical - Questions
    Last Post: 17th March 2009, 10:40 PM
  4. pro's on carbies on 86kw 4age
    By redsprinter in forum Technical - Questions
    Last Post: 12th January 2009, 10:59 AM
  5. Where to buy carbies for 4age?
    By HYPNTK in forum General Topics (No Technical Questions)
    Last Post: 17th October 2006, 05:32 PM
