Hi guys.
Just wondering I've got long control arms with a T3 steering arm but my inner tie rods arent longer enough.
Do they make longer inner tie rods? And if they do where can I get some.
Cheers drew.
Hi guys.
Cheers drew.
burnouts are like jerking off, can be good from time to time, but there are better things to do with your penis.
i have adj. Lca's wound out 25mm longer than oem with the t3 kit and im using uras tie rods and there's plenty of thread. What lca's are you using?
then refer to my question.... my arms are the same length as the T3 ones, and there's still plenty of thread... What Tie rod ends are you using?
Drew I can get you a pair of T3 outer tie rods on their own. Won't have any issues then. Pm or call me. Can prolly just give you a set off a kit I've got here
Sorry I think I mean the rack end
Go to your wrecker and get these tubes and tie rod ends.
They are from ra40, xt130, ke30 and ke50.
Like $6 each.
Sorry guys I didnt explain myself propley.
I've got T3 adjustable LCAs and, T3 steering arms with the long tube that goes over the rack end.
And my problem is that the T3 tube isan't quite long enough, sorry for the noob questions but I just wasn't sure.
Cheers drew
thats what i would be checking Drew, either your outer tie rods arnt installed properly or you Rack ends are different to standard and are to short.
send me a pic tomorrow, or post a pic
ra60 are longer
will check thread
