Does it crank?
Car:ae71 1984 csx
Trans:5Spd
Colour:aqua faded
Rego:feb 20 (is not registered for 4age)
Description:same as all of them, has some rust thats been boged over few dings here there nothing major.
Mods:has a smallport 4age with trd copy extractors,vl fuel pump with 8mm efi lines(also hav a spar vl pump),ae86 radiator (recon),cut rear falcon springs in rear and cut rear commo springs in front pretty stiff(also hav hilux short strock shocks not installed),ke70 auto diff plus a spar welded diff wit broken spider gears and brand new slave cylinders,sound deadining has been removed,kenwood cd player with two 6x9s,thats bout it probly forgot some things.
Problems:engine spun a bearing in cylinder 1 bigend had crank machined new bearings ordered by the guy that machined the crank.replaced all seals,new head studs and gasket.did all this myself(not a mechanic) put it all back together and now it won't run so hav given up on it no time to finish or even look at it.
I'm looking for $1500 or swap for a stock anything with Rego just msg me and ask.
Also hav a t series 2 with trd 2way LSD insert(not installed) the guy I bought it off said it had recently been rebuilt and re shimmed cannot confirm that though.that I can throw in with swap if conditions are right.
Would prefer text or call 0403699791.thanks Sam
Probly won't be able to get pics up but can email them upon request cheers
Location is central coast nsw
Let us know if it over priced guys?
Does it crank?
Yep hav not done a compression test on it though and the location is central coast nsw
Id prob grab this if you were in brisbane. Check the timing might have jumped a tooth good luck
Cheers mate but I just hav no time to do it and my 180 takes all my spare time up hey
Someone take this off my hands
pics?
Sold.......
