Results 1 to 4 of 4
Thread: 3TC on it's last legs?
    Member Revan's Avatar
    Tim
    ACT
    Belconnen
    Default 3TC on it's last legs?
    latest (vary rare mind you) drama with the 3T occured the other night on the way home from syd to gong....
    massive, massive flow of water over the road which i hit doing 90 odd. was like a scene from fuckin red october.
    Started missing really bad, water poured out of the dizzy cap upon removal....
    let it dry out for a couple of days, and got the rags n penetrene all over the half dozen electrical components/leads etc....\
    Still has a consistent miss... drove it like that 240kms today. not too much fun. have no time off nor alternative transport for the next 8 days..
    Is the timing just fucked maybe? Tips on adjustment>?
    thanx guys.
    Veteran biggo's Avatar
    Nick
    Noosa
    Seal up in the radiator.
    It could be a gasket somewhere thats putting water where it shouldnt be tho. But hey, its a 3tc itll probably run on crude oil if it had too.
    Aaron
    so you managed to get water in the dizzy? did you suck up any water thru the motor too? pull the plugs and crank it over to check. if they a bit wet do a comp test and replace the plugs.
    also you might have got water in a spark plug tube causing it to ark out
    Michael
    Jyväskylä
    Ouninpohja
    Finland
    Best way to fix any missing 3T is valve bounce followed by a hefty clutch dump
  1. WTB: 3tc Battery tray and 3TC battery hold down
    By kul_blu_car in forum Cars or Parts Wanted
    Last Post: 18th February 2011, 06:34 AM
  2. What has 8 legs and lives under your sun visor????
    By dave2221 in forum Offtopic Discussions
    Last Post: 19th April 2009, 10:52 PM
  3. What has 8 legs, hair all over and lives in your garage?
    By shadow_bunny in forum Offtopic Discussions
    Last Post: 16th April 2009, 07:27 PM
  4. XT130 strut legs
    By Jonny Rochester in forum Car Parts For Sale
    Last Post: 20th May 2008, 01:10 AM
  5. 3TC
    By stouty in forum Cars or Parts Wanted
    Last Post: 18th November 2007, 04:42 PM
