Results 31 to 40 of 63
Thread: 4AGTE 20Valve track car Fast fours feature car :)
Threaded View
    Billy
    Tarragindi
    Default 4AGTE 20Valve track car Fast fours feature car :)
    Just an update,
    Had a photoshoot last friday for fast fours, will be in first or second issue next year . Here are a couple of photos my friend took with his iphone at the shoot, so keep an eye out for the issue with the pro pics . Engine pics are on my old post pics to big to work for some reason
    These are the specs
    Car makes 180kw at 14 psi with more to come
    Engine:4AGE 20 Valve Silver top
    Engine hardware
    Custom oil cooler kit and filter relocation kit, custom oil catch can and modified baffled sump. Nissan trx bluebird radiator with dual thermos, Ground and balanced standard crankshaft, 20 thou over boar with oversized weisco forged pistons 8.5.1, Shot peen and polished 4agze conrods with arp conrod bolts. Arp race bearings throughout, Arp head stud kit, Angular block modification for big end bearings, Aftermarket valve springs, multilayer metal head gasket, s15 t28 turbo with .49 rear housing, 38mm external waste gate and screamer, Custom plenum chamber with 3sgte throttle body,1jz injectors, Adaptronic ecu, ae101 coil packs, Straight through 2.5inch exhaust, Custom surge tank with braided line and bosch 044 fuel pump and fuel cell.
    Drive train
    W55 Celica gearbox, 4 puck ceramic clutch, E series light ace diff locked and converted to disk with s13 disks with 4.3 diff gears. One peace tail shaft.
    Brakes/Suspension
    Front-Custom made front coil overs with 8kg swift springs and kyb agx 4 way adjustable shocks, Ajps front sway bar, T3 camber tops and custom strut brace, Ae86 power steering arms, Sigma lower control arms and t3 RCA’s, Quaife Quick Rack. Jdm vented rotors with braided break lines.
    Rear- Custom made coil over’s using 6kg springs and kyb agx 8 way adjustable shocks and a T3 rose jointed adjustable pan hard rod. Rear Ajps Sway bar and Ajps traction brackets, rose jointed adjustable rear trailing arms, Nolothane bushes throughout car. s13 rear disks.
    Wheels and tyres
    15 by 8 -4 Super lights all round with 195 50 15 nankang ns2s for now.
    Bodywork
    Hand flared guards front and rear, Repaint in Alpha Romeo Silver.
    Interior
    S15 dash fitted with digital sabre gauges and ace well digital dash, Bride recliner for driver and passenger and Trust harnesses, kkr deep dish suede steering wheel, Trust gear knob. Jap spec turbo timer and custom made hydraulic hand brake and line lock kit.
ID:	14318   Click image for larger version.
ID:	14319   Click image for larger version.
ID:	14316   Click image for larger version.
ID:	14320   Click image for larger version.
  1. 4agte ae86 drift/track car part out
    By _wanna-be_ in forum Car Parts For Sale
    Last Post: 7th November 2012, 08:29 PM
  2. 4agte ae86 track car
    By _wanna-be_ in forum Cars for Sale (Toyota Only)
    Last Post: 15th October 2012, 08:13 PM
  3. Yep another track car from team fast eddie
    By FAST EDDIE in forum KE70 / AE71 Owners Forums
    Last Post: 2nd April 2012, 10:10 PM
  4. Feb Fast Fours
    By maxhag in forum Toyotas in the Media
    Last Post: 25th February 2011, 02:40 PM
  5. buy fast fours!
    By orangechargd86 in forum Toyotas in the Media
    Last Post: 18th May 2007, 02:19 PM
Tags for this Thread
