Results 1 to 2 of 2
Thread: ae101 4agze coilpacks.
    Veteran 86TRD's Avatar
    Luke
    Forster
    Default ae101 4agze coilpacks.
    Car - AE86
    motor - ae101 4agze
    use -
    problem - coilpacks
    occurs/started when - today
    personal situation - annoying.
    So today i unplugged my coilpacks to make a bracket for them, though while doing so the numbers 1-4 and 2-3 were rubber off with out me knowing.
    So i know 1-4 go together and 2-3 are together i just need to know what coilpack they go to.
    on the back off one coilpack it says A-3 and the other says A-6, these are the only differences that i can see between them.
    So do 1-4 goto A-3 or the other way around?
    Any info much appreciated.
    Cheers,
    Luke.
    Jason
    Southern Suburbs
    Trail and error. Had same prob when I put mine together.
    Just plug them up either way. Try to start. It it pops, farts and possible backfire. You got it worng and need to swap them around. If it starts like normal, then they are correct.
    Then paint the plug and coil connector with paint pen (including inside of the connector on the coil pack where you cannot rub it off).
    Jason
  1. [BNE] 4AGZE factory coilpacks ASAP
    By trikzlane in forum Cars or Parts Wanted
    Last Post: 7th June 2011, 08:25 AM
  2. WTB: AE101 4AGZE twin coils (coilpacks) and leads.
    By keiichi in forum Cars or Parts Wanted
    Last Post: 8th January 2011, 05:27 PM
  3. 4agze Accel cable mount, 4agze ae101 air intake temp sensor
    By Roo. in forum Cars or Parts Wanted
    Last Post: 13th May 2009, 07:00 PM
  4. ae101 4agze loom/ecu onto ae92 4agze?
    By 84ae86coupe in forum Technical - Questions
    Last Post: 16th May 2008, 01:30 PM
  5. AE101 4AGZE Flywheel + AE101 215mm 6-bolt Flywheel
    By PuGZoR in forum Car Parts For Sale
    Last Post: 29th May 2007, 08:51 AM
