hey ppl, selling my 91 nissan silvia sr20det redtop king series
113,xxx ks
manual
sunroof
list of mods
hypergear tr43i .63 turbo
tune agent top mount manifold all heat wrapped,
38mm gate with a nice scremer pipe
sard 550cc side feed injectors
bosch 040 internal fuel pump
custom made front mount no holes cooler, xr6 turbo cooler and all custom made cooler pipin by me
53mm dual core aluminium with twin 14inch thermo fans controlled by a drift thermo fan contorller works all the time neva had a problem and new water pump
3inch exhuast all the way to the tip with 2 resisnators
i have a exterm heavy duty brass button clutch i havnt put it in yet, good for 300+ kw
now the problem bits
car is at the tuner at the moment spring motors, i bought a power fc djetro and the board is fryed, ive sent the ecu away to get repaired so should have it back soon and dyno it stright away, so no air flow meter
paint is faded on the front
couple rust spots near the sun roof,
2nd gear syncros arnt to good ( usally s13 gearbox problem)
dash has a crack, also the cluster plays up its got digital display
ive taken all the ac out but have all of it
suspesion is stock
interia is alrite seats r good jus the dash
ive had the car for about 3 years now, never had any big problems with it, did a comp test about 1 year ago 165-170 in all 4, i dont drive the car much as i have a daily to use ive done 7 or 8000ks in 3 years, i use it as my weekend car, always serviced every 5000 or 3 months, never seen the track, its got 17inch momos with good tyres, i did the front brakes with new slotted rotors about 1500 2000ks ago always used mobile 98, and gonna get tuned on mobile 98,
once its tuned hopfully aimin around 220-230 mark only runnin 14psi
reason for selling, need money to fund my new project
open to swap or 8500 with reg till next year september no rwc
i also have all the stock parts for it eg side mount cooler stock t25 with manifold
located in victoria south east suburbs dandenong
call or sms 0432 506 443
WILL GET MORE PICS UP SOON
