Results 1 to 5 of 5
Thread: WTB: N/A 4age Idler Pulley
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Default WTB: N/A 4age Idler Pulley
    Hey guys,
    Im about to run a 175mm 4agze pulley and ive been told i need N/a 4a idler pulley.
    If anyone on the Gold Coast has a 4A parts motor laying around, or just happens to have a pulley for sale please let me know!
    0423 049 869
    Cheers!
    Grant
    Grant
    Gold Coast
    So ive got my new ze pulley and know exactly what i need now.
    Its the Adjustment pulley for a gze, so apparently an NA 4age pulley fits this...
    However im a little confused cause isn't the only things a belt goes around on an NA 4age the H Balancer, Water pump and alternator?
    I wasnt aware there was anything like this, basically im looking for something like this:
    A pulley that free spins when tightened up but probably about 10-20mm smaller than this one (ZE)
    Ok
    Seamus
    Milton
    My reading of the interweb says you are after a 4AGE/4AGZE **timing** belt pulley/tensioner to use in place of the idler pulley. If you don't have monstrous hands, then i'd say the dimensions you have mentioned also add up.
    Or you can possibly use a longer belt
    I may have one of the timing belt tensioners lying around, i will check this arvo. xo
    Grant
    Gold Coast
    Cool cheers 7ox
    Thats pretty much exactly how mine will look:
    Minus lots of dirt...
    Good to have something for reference, t3 also supplied me with the belt number i need which is cool but its a sheet somewhere.
    Grant
    Gold Coast
    Got it all sorted now
    I ended up getting a 4a idler pulley off a wrecker today
    Basically you have to pull off the bracket that sleeves on the bearing and attaches to the spring, bin that..
    Flip the pulley around, run enough spacers so the pulley itself doesnt touch the adjustment bit that you push it up and down on, and on top of that run a spacer inside thats big enough to fit the inside dia of the bearing as well as fits the dia of the bolt... This just prevents the pulley from running around cause its a half moon shape inside it, not an actual hole.
    It's quite punchy now
  1. WTB 4AGE crank pulley
    By GZE016 in forum Cars or Parts Wanted
    Last Post: 2nd May 2012, 09:16 PM
  2. WTB RWD waterpump pulley 4age
    By hachirusto in forum Cars or Parts Wanted
    Last Post: 20th April 2012, 12:25 PM
  3. WTB 4AGE RWD Crank Pulley
    By FKN16v in forum Cars or Parts Wanted
    Last Post: 14th September 2007, 08:58 PM
  4. WTB: 4AGZE idler pulley
    By Tom86 in forum Cars or Parts Wanted
    Last Post: 25th June 2007, 02:56 PM
  5. WTD: 4agze idler pulley
    By jdm hachi in forum Cars or Parts Wanted
    Last Post: 17th January 2007, 02:26 PM
