Results 1 to 10 of 13
Thread: AE86 Front Coil Overs / Struts / Hubs / Rotors
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Default AE86 Front Coil Overs / Struts / Hubs / Rotors
    Hi All
    Have the following in stock
    1/ AE86 Front Coil overs
    Strut size top of bare strut housing to bottom 385mm
    Unknown spring Rates
    Non Adjustable Inserts
    Camber Tops
    Brake mounts / Backing Plates extra $55
ID:	14629Click image for larger version.
    $650 set
    2/ AE86 Front Coil overs
    Camber Tops
    Brake mounts / Backing Plates $ 55 extra
    JDM Ventilated Rotors slotted & Hubs
ID:	14631Click image for larger version.
    $ 650 without hubs & rotors ## SOLD ## or $ 800 with hubs and rotors
    3/ AE 86 Front Coil Overs Bare
ID:	14633Click image for larger version.
    365mm lenght and steel thread.
    $ 185 pr
    4/ AE86 Front Struts
    TRD lowered Springs
    Non adjustable Inserts
    Camber Tops
ID:	14635Click image for larger version.
    $450
    5/ AE86 Front Struts Bare
    Have a couple sets of these
ID:	14638Click image for larger version.
    $165 pr
    6/ AE86 Front Caliper Mounts
    $55 pr ## SOLD PENDING PAYMENT ##
    7/ AE86 JDM Front Ventilated Rotors & Hubs
ID:	14641Click image for larger version.
    $ 200 pr
    8/ Have another set of coil overs similar to the other also, but still on front cut
    $650
    9/ Various sets of used JDM ventilated rotors
    $70 pr
    PM if interested or give us a call
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Craig
    Upper Caboolture
    pics added
    Veteran slydar's Avatar
    Dimitri
    re our phone call ill definitely take those caliper bracket thanks Craig.
    78's
    ACT
    Compton
    hey mate,im after a few bolts.i have coilovers,brakes hubs,power steering arms.i just need whatever nuts and bolts needed to assemble the struts fully so i can fit them in my panelvan,can ya help??
    ACT
    Compton
    eh????
    Craig
    Upper Caboolture
    Hi
    Not sure exactly what you are after
    Bolts that bolt the str arms to the bottom of the strut ??
    Bolts that bolt the rotors to the hubs ?/
    Bolts/ nuts that bolt the lower control arm to the subframe ??
    Bolts that bolt the backing plate/ brake caliper mounts to the strut ?
    Caliper Bolts ??
    ACT
    Compton
    all of thbose would be great except bolts that bolt the backing plates to the struts as i have them..would you have those spair?thanks mate
    Craig
    Upper Caboolture
    Hi
    Quite busy at the moment, will see what i can find when i get the time
    ACT
    Compton
    that would be great mate,need to get my ke decked badly!
    Senior Member billett86's Avatar
    Mar 2010
    Toby
    Adelaide Hills
    Do you have any pairs of ae86 front hubs and discs?
  1. Replies: 0
    Last Post: 24th June 2012, 12:57 PM
  2. Front set of Custom Coil Overs to suit a AE86
    By trueno_slide in forum Car Parts For Sale
    Last Post: 5th May 2012, 01:29 PM
  3. Replies: 7
    Last Post: 6th June 2011, 08:51 PM
  4. Replies: 40
    Last Post: 27th December 2007, 10:08 PM
  5. s13 coil overs an sprinter struts
    By Trucka 115 in forum Car Parts For Sale
    Last Post: 1st November 2007, 07:38 PM
