R33 GTST brakes will fit under pretty much every 16" rim.
as above thanks
It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
they fit under 15' wheels aswell no worries, but the design of the neg 4 superlites may require a 5 - 10 mm slip or the like.
nah they def fit
I already got
The 15s last time a tryed wasn't anygood needed like 25mm bolt on but I didn't really look...
Anyone no what 16s are worth
Check out my build thread ( SD garage 86) they 100% fit under 15's
I dno about not needing a spacer Dave. I'm running 15 x 10 neg 12, these have a heap more caliper spacing then the neg 4 superlites.
The rotor on the outboard side of the hub adds 7mm and a 5 mm slip on was needed to clear the spokes.
i was talking about 16s tho
ahh no worries.
above is defiantly the case with 15 x 10 superlites
