Results 1 to 7 of 7
Thread: no clutch
    Senior Member bones's Avatar
    Apr 2010
    Brandon
    Geelong
    Default no clutch
    CAR - ae86
    MOTOR - small port 4age
    USE - skids
    PROBLEM/QUESTION - alright when i start up the car the clutch is all good goes into gear fine and all that when i drive it for about 10/15 mins the cluch goes softer and softer the longer i drive it till there is fuck all left and i gotta smash it in gear. could my extractors be boiling the break fluid or somthing like that ? any help would be great!
    OCCURS/STARTED WHEN - when i replaced the clutch
    Senior Member macca1590's Avatar
    Central Qld
    yeah heat boiling fluid would be it, especially if the line runs on that side of engine
    and maybe when you replaced the clutch somehow the line was moved closer to exhaust
    Apr 2010
    Brandon
    Geelong
    awk does anyone have a pic of how the lines should run? I did replace the clutch master aswell and it is a different one has 2 screw parts insted of one i belive , thanks!
    Moderator Sam-Q's Avatar
    Endeavour Hills
    would you like a RWD compatiable clutch line?
    Veteran stx-16's Avatar
    Tweed Heads
    just heat wrap the line and your extractors
    you play halo?
    add me GT: samnbhnc
    Endeavour Hills
    that's not meant to be real good for your pipes.
    I guess ideally a heatsheild around either, even in the form of some bend sheet.
    We really need a pic though to see what he has done
    Apr 2010
    Brandon
    Geelong
    i heat wrapped my extractors the other week thinking that would work but no go , il try around the pipes cos i got a bit left, il post a pic up soon, thanks
  1. Replies: 1
    Last Post: 19th October 2010, 04:30 PM
  2. altezza beefed up clutch new with clutch disc and carrier bearing
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 15th June 2010, 11:15 PM
  3. Replies: 4
    Last Post: 4th January 2010, 09:42 PM
  4. wtd t50 clutch fork clutch t18 rear bar etc
    By wanabdrifta in forum Cars or Parts Wanted
    Last Post: 13th July 2009, 11:49 AM
  5. Melb: Pedal assembly, hard clutch line and clutch master
    By stahlz_ae86 in forum Car Parts For Sale
    Last Post: 31st March 2009, 07:04 AM
