what specs do you want? I might have another option
Hey guys just wanted your opinion
What are your views on cams getting custom made from the cam doctor for my 4AGE?
I can get these at a good price, have looked at HKS, tomei or toda but the price they want for the specs i want
is just out the budget, i have already purchaed HKS cam gears and HKS valve springs to go with the new cams
Any helps would be great. Cheers Allan
265 duration both exhaust & inlet with 8.5mm lift
My honest opinion, is to go with tried and tested companies, Toda, HKS, Tomei or TRD.
They are expensive in comparison due to R&D and testing costs.
Manufacturing quality is second to none, and guaranteed to work, even to the cam timing specs which may need a minor tweak to suit your engine.
Save coin, do it once, do it right.
Big up's for the North East Massiv'
NSATB - New Skids Around The Block
There are other companies with off the shelf options. Wade and crower I think both do a few different sizes? I'm sure there are more just have to look harder.
kelford and camtech both do that duration and lift.
camtech i would not trust but kelford hells yeah cheap as chips and they are good i know from experience on another note i run second hand hks shafts they work very well if i where you go a good brand of cam wait a little longer till you have the coin if your going to spend a lot of money on a motor you might as well get the good parts
the dyno pull to 300rwkw
You know you don't have to buy Japanese to get something good. I know of a proven vvt compatiable 270/270 combo but it's higher lift. I need to see if they can do a more sedate lift and then I might go ahead and become a reseller. I know they are a proven thing as I have first hand seen the dyno charts on a friends engine. Best bit is they are cheap as.
why bother with such small duration? have you driven any cars with cammed up 4AGEs? worst thing you can do is go too small because of imagined drivability problems.
