Page 17 of 18 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 161 to 170 of 174
Thread: Building a 7age.
  1. #161
    Apr 2013
    Cool good to know so I can just up the fuel pressure with the adjustable regulator until I find the sweet spot and just cruise around with the blacktop ecu without dramas until I save up for the adaptronic e420d. I know the 20v injectors would be adequate to keep for now but when would it be ideal to change them to higher ones?
    I figure if I were to go with aggressive cams over 272 duration it might need new injectors but I'm just using Tomei Poncams with 264/256 duration and some some general head work and compression around the 12.0:1 mark.
  2. #162
    Apr 2010
    Hills
    well im planning on building a turbo 7age. Just low compression and what would hold up to high boost.
  3. #163
    Feb 2014
    Doman
    Pest
    Gödöllő
    Hungary
    Good thread here, I've read the whole thing, I got a little smarter. I have an AE86 with AE92 smallport engine, TechnoToyTuning ITB adapter, AE111 45mm ITBs, 272/8,1 HKS cams with HKS springs, TRD USA 4-1 copy header, and megasquirt ECU.
    I've bought now a nice 7A engine, all look pretty good, the cylinder hone, the bearings, etc. I want to make little more power out of my old engine.
    I plan on using silvertop pistons ( I have a set on the shelf) as they are stronger (with the drilled oil return ring pits), lighter and have higher CR than the smallport ones.
    I have a serious question. Is there anyone who have teared a stock 7A conrod?? I'd like/plan to use it as it is. If anyone says his engine was blown because of the stock conrod I'll buy an aftermarket set.
    Also I'd like to ask you all about the timing belt. I've read Porsche 944 - 1986 and Peugeot 205 GTi aswell.
    Which one is good/better? Am I right that the peugeot is shorter and is for the 20V heads?
    The shop where I can buy them has 2,5 - 2,7 and 3l porsche 944, and 1,6 - 1,9 205 GTi Peugeot. which one to use? the T107 is enaug for the porsche belt and BT111 for the peugeot belt? these are the codes I need?
  4. #164
    Senior Member d1staz's Avatar
    Feb 2011
    Ron
    footscray
    I'm using the Porsche 944 belt on my bigport 7age. From memory it's the 117 tooth belt. Not sure of the part number though. I can check for you later tonight.
  5. #165
    Feb 2011
    Ron
    footscray
    This is the belt I'm using
    7age (16v head) - Porche 944/924S dayco #95107 117tooth
    Hope this helps.
  6. #166
    I built one with stock conrods and it was ok, but for the extra $300 odd for after market rods it isn't too much to invest in if you are worried.
  7. #167
    Chee
    SOR
    I've been looking into building one of these and am wondering what type of rod to stroke ratios are people ending up with?
    From what i can gather those with the J-Works rods end up with a ratio of close to 1.5 (since they are similar to speedracers) and does this in any way affect the nature of the engine?
    As I plan to build a 7AGE which retains the rev happy nature of the 4A.
  8. #168
    Veteran drift kid's Avatar
    Glossodia
    Being larger displacement it will be more torquey and not as much for a 4ag style revvy motor, i have whitnessed this from many 7ag builds, it's just the nature of gaining capacity
  9. #169
    Chee
    SOR
    So with aftermarket rods it will have the capability to rev to 7-8k more reliably then the stock 7A rods however it will feel less eager to do so?
    I'm currently drawing up plans for my engine build and am looking at the different avenues. I've come to the fork of either 5A or 7A but from what you've said they're both going to behave like a 4A?
  10. #170
    Glossodia
    Well the motor will most likely be making its power a bit lower in the rev range than a 4ag due to the larger capacity, and there is no point revving an engine to 8000rpm if it's power curve dropped off at 7500rpm
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
