Results 1 to 6 of 6
Thread: Idle and fuel problem, running rich
    Senior Member capatown's Avatar
    Nov 2009
    Aarron
    Southside
    Default Idle and fuel problem, running rich
    CAR - AE86
    MOTOR - smallport 4age
    USE - drift/street
    PROBLEM - At idle car revs from aprox. 1000rpm to 2000rpm constantly, pretty sure car is running way too rich
    OCCURS/STARTED WHEN - Possibly from a bad batch of fuel ? maybe not, just happened.
    PERSONAL SITUATION -Tried adjusting the timing, it made no difference at all. Put a new fuel filter on, still the same.
    Im pretty Sure it's a fuel issue as it's not missing at all, ive played with the timming and it doesnt make any difference at all.
    Im not sure where to look next, could be a vacum problem ? Or maybe the ecu has gone into some weird limp mode ?
    It's running rich for sure, nearly like its surging, heres a little video of it idling, like I said im not sure what to check next.
    Any help would be muchly appricated!!!!!
    Veteran timbo's Avatar
    Tim?
    Wild West
    it seems to be hunting... check the TPS and rule that out at least.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    hunting big time
    Nov 2009
    Aarron
    Southside
    All fixed was a leaky throttle body gasket.
    Thank guys!
    Michael
    Crimebrook 2749
    good to hear
    Tim?
    Wild West
    good work. my idle is slowly creeping up which leads me to believe i have a vac leak on the inlet manifold...
  1. Strange idle, running rich, please help
    By Sprinter Freak in forum Technical - Questions
    Last Post: 29th April 2012, 10:34 PM
  2. Running rich?
    By Ham86 in forum Technical - Questions
    Last Post: 17th March 2011, 07:22 PM
  3. Running rich
    By RolandGTV85 in forum Technical - Questions
    Last Post: 24th April 2009, 11:10 AM
  4. Running Rich
    By grape_moosha in forum Technical - Questions
    Last Post: 29th January 2007, 11:28 AM
  5. running rich
    By Maxhag in forum Technical - Questions
    Last Post: 1st June 2006, 06:52 PM
