You need to read the previos sentence too if you want that to make sense, so it reads:
"MS2 only has outputs for distributor and two for injectors. If you want sequential you can run MS2X and extra boards for 3/4 injectors and another for 2/3/4 coilpacks and you need the board for the second reluctor input."
MS2X is an optioned out MS2 which allows you to take logic signals from unused pins on the CPU. These signals are very low current and only 5v. You need the boards to boost the signal to 12v plus throw some real current at an injector. You solder into some points and run these to separate boards that mount inside the ECU to run your 3rd and 4th injector. Same deal for the waste spark/sequential spark. Take unused pins and condition the signal so it can trigger a coil to spark. Not really needed if you go and raid 3 Camiras for Bosch 008 ignitors. The spark output on a MS can directly drive a coil without an ignitor, up to you if you want to run external ignitors or solder up a board that does the job of the ignitor.
The last bit about the reluctor: Toyotas run a variable reluctor pick-up/sensor in the distributor to sense the rotation of the wheel. This signal requires conditioning through a LM1815 chip and a bunch of resistors and capacitors needed to make the chip function in the correct mode. The MS v2.2, v3, and v3.57 PCB's only have one signal conditioner. The newly released MS3 daughterboard has one built onto it while the MS2 daughterboard doesn't.
