Results 1 to 4 of 4
Thread: oil pressure senders, interchangeable?
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Default oil pressure senders, interchangeable?
    Just wondering if the oil pressure senders on 4age's and 4ac's are interchangeable?
    I have got a 16v 4age in my ae71 corolla and it seems to be sending a different kind of oil signal to the light in the dash, so can i just swap the 4ac one into it and be good as gold?
    Cheers, Will.
    SuperFunHappySliders
    SR's are ghey.
    Veteran Skylar's Avatar
    Ken
    It's not engine that matters, it's the car. AE71 and KE70 senders are switches while AE86 are sensors. Use the sensor that was on the original engine.
    Will
    Northern 'burbs
    Thanks mate.
    Yeh i had a feeling the 4ac that was in the car was a switch type, so obviously the engine i have just put in has a sensor-type sender.
    So back to my initial question, will i be able to simply swap them? or will they be different thread pitches? (which i highly doubt, but its easier to ask than, find out the 'other' way)
    SR's are ghey.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    all the A-series blocks are just variations of each other. The thread is identical between all of them
  1. WTB: Oil Temp and Oil Pressure Guages
    By Futo_gt86 in forum Cars or Parts Wanted
    Last Post: 20th November 2011, 09:33 AM
  2. Replies: 4
    Last Post: 16th May 2011, 01:13 AM
  3. FS: Omori Oil Pressure & Oil Temp Gauges
    By Nebuchernezzer in forum Car Parts For Sale
    Last Post: 14th November 2007, 07:50 PM
