Results 1 to 10 of 16
Thread: VIC EXTRA LOCK NUCKLES!!! 86 and e7
    Calvin
    Kilsyth
    Default VIC EXTRA LOCK NUCKLES!!! 86 and e7
    hey
    ITEM 1- 1 pair of ae86 nuckles cut and welded professionally (jdi fabrications) to make for awesome lock, correct ackerman and help with bump steer
    ITEM 2- 1 pair of ke70/ae71 nuckles cut and welded in same fashion by same professional
    LOCATION Montrose, Vic
    PRICE 120 per pair
    CONTACT pm or reply here
    Cheers, Calvin
    T18 in the build
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    are these the ones with the arm welded on the underside?
    know how to tell if you have ae86 struts? i just picked up a ke70 with random mods and a 4agze ^_^ i might grab the ae86ones if i work out what struts i have.
    also - how you doing dude
    Davey & Riki-lee
    South Australia
    Seaford SA
    best knuckles! its what im running refer to ridiculous lock pictures of mine lol
    Our introduction - Click here
    Veteran KurtHS's Avatar
    Kurt
    East Melb
    What LCA's are you using AE70? Dave right?
    Member A.k.'s Avatar
    Jul 2010
    Alistair
    Rosanna
    I'll take the ae86 ones. Can you pm me your address and I'll pick em up tomorrow.
    Cheers.
    Calvin
    Kilsyth
    only way i could suggest would be to pull the knuckle out and measure the bolt holes. if you want some pm me and i'll sort it out.
    ak pm sent
    T18 in the build
    Davey & Riki-lee
    South Australia
    Seaford SA
    Yeah thats me, im using ajps rose jointed adjustable ones
    Veteran blair's Avatar
    Blair
    SEQ
    how long do you have them set man?
    i wouldn't mind some extra lock, but at the moment im very close to hitting the inner guard on lock in both directions with just lock spacer and pwr steer arms!
    Have you beat the living shit out of your car or somehting?
    Kurt
    East Melb
    Hey blair if you're interested in these knuckles I can chuck on my 8's and tell you if they scrub, I can only do it stationary though. I have these JDI knuckles and XT130 LCA's at the moment, did have sigma's.
    ... but I don't have any alignment details so that may change things up a bit.
    Davey & Riki-lee
    South Australia
    Seaford SA
    With the wheels i am using atm i had to use a spacer to clear the tie rod end as the angle of the knuckle is different. I have got something silly like 20mm bolt ons to clear it with the bottom arm all the way in (still longer then normal) and camber tops out just a bit, with the 14x8 -10 they stick out quite alot as you could imagine refere to pictor
    But it gives you lots of lock which is handy at the worst times!
    But yes i still get some rubbing but no cutting which is good and i dont worry about it too much
  1. Extra lock question?
    By Alexrex7 in forum Technical - Questions
    Last Post: 1st October 2012, 10:34 AM
  2. 86 extra lock rack ends
    By bigdaddykane in forum Cars or Parts Wanted
    Last Post: 24th April 2010, 01:14 PM
  3. Extra lock spacer
    By loc33e in forum Technical - Questions
    Last Post: 22nd January 2008, 05:45 PM
