Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: heavy steering
  1. #11
    Glenn ke_70's Avatar
    Clay
    Barossa!
    jack the car up and turn the wheels by hand.
    thats where id start.
  2. #12
    Paul
    Maidstone
    it is castor as its high.
    also toe out is not a good thing .
    2 in the pink 1 in the stink
  3. #13
    Jake
    Northgate
    when you increase camber im pretty sure you have to use more toe out and that should make it lighter. Also did you replace the bushes and ball joints before you put them on or where they still good? and you cant tighten the lcas when the suspension is drooping you have to jack the wheel up to ride height then tighten the bolts. I had a mate that tightened them (standard arms) when the car was up in the air and it had +camber.
  4. #14
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    bushes and balljoints in the LCA are brand new, dont remember playing around with castor ? plus i only have stock castor rods so it cant go that far
  5. #15
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    but as someone said above caster rod mounting point on LCA's are different and could of pulled/changed your caster, take it and get them to do a caster and camber allignment
  6. #16
    Clay
    Barossa!
    hard to tell on the internet.
    take it for an alignment. they'll soon tell you whats wrong you need one anyways
  7. #17
    Senior Member Stain's Avatar
    Derek
    Far North
    When you put longer LCAs in without adjusting the caster you'll naturally get more which will increase steering effort...
    That combined with you not driving the car for awhile and not being used to it would make it seem rather hard...
    I don't drive my sprinter much anymore... but I always forget about the heavy steering and try n go one handed thru town. Always a shock :p
  8. #18
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    what stain said makes sense - now that i think about it, my old rona had decent castor, about +6 and it was almost impossible to turn to full lock when stationary. i'm not exactly weak either.
  1. heavy steering
    By ae86ln in forum Technical - Questions
    Last Post: 17th April 2010, 11:37 AM
  2. heavy steering
    By redsprinter in forum Technical - Questions
    Last Post: 20th November 2009, 09:18 PM
  3. xt130 struts and heavy steering
    By rogg in forum Technical - Questions
    Last Post: 25th September 2009, 10:50 AM
  4. Replies: 16
    Last Post: 15th November 2006, 07:13 PM
  5. Steering heavy when turning left ?
    By HiLtOn in forum General Topics (No Technical Questions)
    Last Post: 3rd August 2006, 01:33 AM
