u cant see.... but im dancing right now
It moves!
Clutch works, alternator is charging without the warning light (fixed uber bad wiring), oil thermostat works, water thermostat works, and no leaks :-)
Figured out why the motor used to be really hard to start sometimes... My thermos run through a relay from an ignition wire and they pull a metric dickload of current! Unplug the fans and it's like a regular car!
Any ideas on how to setup a temp switch? I can't be fucked right now lol
:-) super happyyyy
06/07/2011
nice man! yer i have never had a drop of oil leak and mines up that way. cya soon bud
Few little things done tidying up for roady:
-Replaced fluro pink wiper blades for new black ones
-Replaced fluro pink tyre valve caps with regular black ones
-Replaced stupid blue headlight globes (one not working) with regular ones
-Installed stereo and my old/decent speakers (speakers that were in it were in these MASSIVE pod things - couldnt even use the accelerator pedal properly!!)
-Installed guages - have confirmation that the oil thermostat setup is workinggg
-Replaced tired hatch struts with my fresh ones that give people split chins from coming up so fast haha!
Hachi's with stock suspension drive like a piece of shit with wheels lolol.
Oops, also got rid of most of the side bumpstrips! so tedious!
moar pics!
Haha, pics of what? it still looks the same!
Picked up a new diff on 'straya day. Te72 with swaybar mounts welded on
Now Gotta get it ready to hot-swap for straight after rego (i will literally drive it home from QLD Transport and get stuck into it LOL)
Gotta Get new seals for axles and housing, Hunt down some 4.8's, rebush new/straight trailing arms, bolt traction brackets on / tail shaft etc etc
This is the shittest thread. Give me 3 months and hopefully it will deliver the GOODS
i wanna see it i wanna see it i wanna see it!
need pics of you doing said work blair, or i wont believe you
~KEEP DRIFTING FUN~
You just want to see him bent over and all dirty trikz
hahaha shhhhhhh![]()
~KEEP DRIFTING FUN~
