Results 1 to 10 of 14
Thread: Complicated steering question
    Sutherland
    Default Complicated steering question
    Hey guys,
    I have spaced my engine xmember down 2 inches to
    make my f20 fit without cutting my tunnel. Now my
    problem is that my steering column doesn't reach my
    rack. I can't find info from guys overseas who have done
    their conversion the same way. Any ideas?
    I'm thinking of taking the steering uni off from the rack
    and welding 2 inches to it to extend it.
    Cheers, ben
    Moderator Sam-Q's Avatar
    Endeavour Hills
    there are different shafts available off other models which have different lengths. I suggest you start your search at a self serve wreckers in the Corona section.
    I know why one would, but you do know it's not really good what you did in regard to the suspension right?
    Will
    bullshit, just bolt on two pairs of RCAs and off you go, might have to run 20 inch wheels though.
    Veteran stx-16's Avatar
    Tweed Heads
    yeah i would rather cut the tunnel up then space the cross member out but its your car
    you play halo?
    add me GT: samnbhnc
    Endeavour Hills
    I agree if he knows the dissadvantage of the steering and accepts that for avoiding the huge hastle of cutting up the trans tunnel then that's his choice and I respect that.
    BTW kick arse price on the Haltech installs
    Endeavour Hills
    yes I stand corrected, if you bolt some RCA's that are 51mm (imperial = shit) + how much the car has been lowered then your back to stock geometry. So some 100mm RCA's and you should be good.
    Senior Member Anthony's Avatar
    Anthony
    a lot of 4wd body lifts involve just cutting the column above the uni, slipping some tube over each end and welding. not recommended though.
    another alternative is to run a power steer rack fluidless(or connected??) with a manual column.
    thats all i got
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Powersteering rack with the guts cleaned out of it is a good idea. If not you might be able to get a longer uni joint from a few places
    Andy
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    if ur got the skill, get a tunnel from a bigger car like a commo or falcon and cut and shut it in to u car, that way it will still appear stock, or if its just for a track car get a tunnel fabbed up,
    Dec 2009
    Andrew
    California
    Nothern
    USA
    MKIII supra intermediate shaft will solve your problems:
    Andrew
  1. Steering rack/tie rod question
    By wideslider in forum Technical - Questions
    Last Post: 12th November 2012, 09:07 AM
  2. Steering column/rack question...
    By corey70 in forum Technical - Questions
    Last Post: 5th April 2009, 09:58 PM
  3. Quick steering wheel question
    By all torque in forum Technical - Questions
    Last Post: 2nd March 2009, 08:16 AM
  4. Steering question + mods?
    By muncher in forum Technical - Questions
    Last Post: 29th September 2008, 03:25 PM
  5. Steering Rack Question
    By 86 Nick in forum Technical - Questions
    Last Post: 27th February 2008, 10:25 PM
