Hey guys,
The time has come to sell my beast, i don't really want to honestly as this car has really grown on me and it will hurt to see it leave.
I will be back in one of these again some day soon, i want it to be driven rather than sitting out the front wasting away i haven't even used the back seat before FFS.
It handles awesome for what it is, but at a price it is really really really stiff, it also brakes really well to.
Item: 1982 KE70 Corolla
Website: Here, toymods, twincam.au and Rollaclub
Item Condition:
Reason for Selling: Getting something else
Price and Payment Conditions:
$1800 o.n.o with the gearbox and new clutch installed + spares
$1650 o.n.o with out the gearbox and clutch installed + the new clutch and 15XXXXkm 4sp G/B + spares
$1500 o.n.o with out the gearbox and clutch installed and no stereo & no spares
Extra Info:
It has the following:
Registered in the old boy's name so it has PENSIONER reg to Mid February, YOU will have to pay an additional $50 or so unless you are a PSNR, but does not need a Pink slip until August Next year.
Engine
4k 372XXXkm but still going strong (No smoke or any shit like that)
4sp
2 inch straight-through exhaust
Electric thermo fan setup wired to a switch on the dash.
Suspension
xt130 front struts, unknown shocks
xt130 LCAs
xt130 rotors
rt132 twin-piston calipers
Sigma GSR 'Pepperpot' 15x6, with Kuhmo KU31's up front with about 75-85% left and Pirelli P6's on the back that need changing soon.
NEW- Whiteline 24mm front sway bar (less than 2500k's old)
NEW- AJPS 8kg Front springs 210mm (free height, with 1/2 a coil cut out) (less than 2500k's old)
Pedders EL falcon rear springs (with a few coils cut out)
NEW- KYB excel G Suzuki Seirra shocks (Super short and heaps stiff too.)
Just Jap? front adjustable strut brace
Interior
Rear seats and door trims re-trimmed in black and red velour (it's pimp, yo)
Front bucket seats (a bit worn and sun-faded in parts but still comfy!)
Tacho dash (Works fine)
Black carpet (no carpet in the front cause it was fucked, but from the front seats back the interior is immaculate)
All plastics vinyl coated in black some wear and tear
Steering wheel, gearknob and pedals to match- look a bit ghey IMO
Window tint
Sound System
Pioneer head unit, nothing special but does the job.
Alpine SPS170A 6.5" fronts
Apline SPS690A 6x9" rears
Apline V12 4-channel amp.
The system goes pretty good for what it is and was more than adequate for me!
In the last 12 months, The previous owner replaced the following:
Brand new battery ($140 )
New rear wheel cylinders and brake shoes
New front wheel bearings
Spares:
15XXXXkm 4sp gearbox if not installed
NEW- clutch kit
NEW- Nolathane xt130 LCA bushes
NEW- Timing chain and tension plate
Haynes Repair manual
Full set of king springs ( uncut )
Monroe rear shocks to suit (in good working order)
Standard Front sway bar
Issues
-Rust around the boot seal needs to be cut out and a new section welded/riveted in ATM it has silicone everywhere to keep most of the water out, as that was the way i bought it and i was going to get the rust removed properly so i didn't bother.
-Rust around the petrol filler again i was going to cut the whole filler cap section out and plate the area thus deleting the external filler, but never eventuated.
-Little rust in the gutters not terminal
-The usual dints for a car this age
-Needs a wheel alignment
-Really small oil leak from mechanical fuel pump, i didn't fix this as i was going to use an electric pump and delete this one but i can chuck gasket paper in with the car if you want.
-the gearbox needs replacing as the layshaft bearing has shat itself- still 100% drivable though. but depending on Negotiation this could be fixed.
-The starter motor plays up sometimes which isn't unusual for these, but it will always start eventually whether you clutch it or the starter works again, this could be easily fixed by installing a Relay instead of using the solenoid.
Pictures: some fresh ones will be up in the next day or so.
Contact Details: PM me here
If you want to know anything else PM me.
EDIT:
Also forgot to mention it has projector beam-ish lights installed that are only 3weeks old they cost me around $80, but coupled with the ksev shit power outage to the lights they aren't that good but they would be awesome with a HID kit(which i was going to do but never got around to it).
BUMP sʇunɔ!!! price drop
$1650 with the G/B & clutch installed
$1500 without but still includes G/B & clutch
$1300 for the car minus stereo, G/B, clutch and spares
I need this thing gone pretty soon, make an offer
Last price drop!!!
$1300 o.n.o without the spare springs and shocks and no stereo but WILL come with clutch kit and G/B.
On ebay
Will also take as a part trade some 4x110 PCD 12-14" rims and cash on top
There is easily $1300 worth of parts if you parted it out + the flat front $200-$350+ other panels/diff/glass/scrap metal/engine
Now wrecking!!!
what would you wont for box and pedal box (everything for manualconvo)
Link to parts and prices
On HOLD!!!
Sold!!!!!!
