Results 1 to 10 of 11
Thread: Starter motor replacement for smallport
    Senior Member capatown's Avatar
    Nov 2009
    Aarron
    Southside
    Default Starter motor replacement for smallport
    Hey guys,
    Sorry if this has been covered before......
    starter motor crapped out today, just wondering what other starters I could use.
    Motor - 4age smallport
    I heard any 4a starter will fit?
    Hopefully I havent striped the fly wheel, it was making an awesome grinding sound.
    Runcorn
    Sounds nasty. I'm keen to know this too. I thought they would all work but what do I know.
    Veteran timbo's Avatar
    Tim?
    Wild West
    one word, NEW.
    mine went about a month ago. Go and see a bloke at Auto Electrics Australia over at:
    16 Hampshire St
    Archerfield 4108
    3277 4566
    Brand new Denso reduction starter from a 22re for $190 with warranty. The bloke is a celica nut and runs the same setup. He actually changed the front housing on the new one to my old one as the angle of the starter would foul on the exhaust.
    Has more than enough torque to turn my motor over, sounds like a truck starting!
    Veteran Skylar's Avatar
    Ken
    Small port are reduction starter. Bigport are direct drive. They all swap over but the reduction starter sorta takes up more space and outputs more torque, not that you need to worry about this on a little 4A. All the direct drive ones are 0.8/0.9/1.0kw units and can be used on swapped with any other direct drive unit as long as you swap the nose over.
    The reduction starters are a little different but as long as you get one off a similar sorta car(NOT a diesel corolla) they should work. I'd just get one new or have the old one rebuilt for 150 or so.
    Nov 2009
    Aarron
    Southside
    Thnx for the info guys.
    Def will be putting a new one in.
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    what are the 20v starters are they gear reduction?
    the dyno pull to 300rwkw
    Mathew
    Sutho Shire
    ok so 20v dosnt fit either does 22re so people dont atempt it i just did im going for a smallport one now
    Tim?
    Wild West
    22re fits, you need to change the front housing that bolts to the bell housing. i attempted it and won.
    Mathew
    Sutho Shire
    do u have pics of how this was done because i stripped my starter and the new 22r and there is no way it was going to work
    Tim?
    Wild West
    get pics for you tomorrow/today, when the sun is up.
  1. starter motor
    By ae86rally in forum Technical - Questions
    Last Post: 2nd September 2009, 12:33 PM
  2. smallport starter motor
    By 70fun in forum Cars or Parts Wanted
    Last Post: 8th July 2009, 10:01 PM
  3. Need help with starter motor
    By hugh in forum Technical - Questions
    Last Post: 19th September 2008, 07:34 PM
  4. Starter Motor
    By ae71neo in forum Cars or Parts Wanted
    Last Post: 2nd July 2008, 05:03 PM
