More pictures.
As some of you know I have been in-trouble with the police a bit and I like to street heaps, so I needed a car that isn't going to draw attention, and be as non-defect-able as possible, or at least look like it.. R31 seemed the best option at the time, but I really don't like them at all, should have gone a KE70.. But this will have to do until I am on my opens/first defect clears around oct 2011..
So, I bought this a few months ago stock, drove it around for a bit, ran out of rego while I had no license. Put coilovers and a few bits in it and blew up a bottom end and raped the clutch in two sessions. NICE, I thought RB30 bottom ends were unbreakable...
So here is the mods list so far...
Engine
S3 "stage 2" head, ported and polished, "Stage 2" lifters, rockers, "32/74" Mild cam, everything port matched.
Bosch Super Sports Ignition leads
Hectic pod + VN adapter.. Plastic ones kept breaking
170,000km bottom end from auto
10:1 compression, over stock 9:1
AU thermos, secondary off temp switch
GREDDY/GREX Sandwich plate with thermostat, FC oil cooler, speedflow lines and fittings.
Extractrors, 2.5"exhaust
Drive line
4x 15x7 watanabes with 205/50 proxies
2x 15 x 6.5 watanabes
Exedy HD clutch
RB20 Gearbox
Welded 3.9 diff
Suspension
ZEAL function coilovers 8/6 rates
SR20DET front brakes, hubs and Boxed LCA's
Rose jointed tie rod ends
Alloy steering shaft spacer
Superpro rack bushes
Whiteline rear sway bar
Boxed rear trailing arms with superpro bushes
Superpro top trailing arm bushes
Inside
No sound deadening
Seam welded engine bay, basic seam weld inside
Pop riveted door frames
Silo seats
Cool stickers for HP
Outside
Bad paint
Rust
Need/to do:
KA24 throttle body (From U12/13 Pintaras)
Install Lukey muffler, gut cat? and remove hotdog.
S14 DMAX castor arms, install modded boxed castor brackets.
Pinnie diff, 4.1 ratio
20-25mm spacers for rear?
Bride fixed back or recaro recliner (+mod plate)
Steering wheel
Hydro handbrake
Some pictures.
I hate this car even more when I get to drive my girlfriend's everyday...
More pictures.
I hate this car so much, I haven't given it a name.
dirty nissan.
Next car will ooze awesomeness hopefully. NEED A JOB.
cool. At least its better than nothing! Or is it?...
John 1:12
So did all factory auto's have the higher CR or does this have some funky pistons?
i know you hate the thing but here's some inspiration...
hahah he said he doesnt want to draw attention to himself
