Results 1 to 8 of 8
Thread: Problems starting BP 4a when hot
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Default Problems starting BP 4a when hot
    Hey guys,
    This has been a recurring problem for quite some time but I'm finally getting sick of push starting it.
    When I go for a decent drive and the car is fully warm coolant/oil. If I turn it off and try starting it again straight away I can't fire it. It will crank a few times then start getting slower as the battery dies.
    If I wait 5 mins it will fire first go no worries and same if it is roll started.
    I've checked the battery, runs 12.65v when the car is off and 14.31v when the car is running, so alternator is charging.
    Just trying to work out what it is before I set fire to it.
    Senior Member bones's Avatar
    Apr 2010
    Brandon
    Geelong
    yeah happens to me with my smallport man , no clue maybe starter getting to hot ? :s
    Feb 2010
    Andy
    Penrith
    My smallport also did this when it got hotter than usual at a drift day recently then once cool would start no problems. I think its the solenoid on the starter motor getting lazy when hot.
    Aug 2010
    Ryry
    Gold Coast
    hey,
    I had a similar issue with an sr20 engine just recently, turned out to be a faulty coolant temp sensor, it was dumping excess fuel for cold start even when it was hot, causing overfuelling, so when I went to start it after parking up for a bit, it would crank and crank but no fire.
    could be something to check anyways, im a noob to 4a-ge's =\
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Have unplugged cold start injector, not that it was working anyway, see if that makes a difference.
    Thanks for the help guys. I noticed my starter is missing the heatshield from around the solenoid. Might look into getting a reduction starter anyway.
    Nov 2010
    kim
    Shinjuku-ku
    Japan
    how did this work out?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    wrap the starter in that heat shield shit (get it from repco)
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Hard to tell, weather has been up and down and not running as hot. But it was still doing it the other day and couldn't find another starter as the day I looked everything was closed. Have one of a mates car yet to go in. Seems like it's just the starter solenoid though.
  1. gze starting problems
    By ae86ln in forum Technical - Questions
    Last Post: 5th August 2009, 06:55 PM
  2. FS: Ae92 4a-gze 650$ or swap with fwd 4a-g
    By Mickey H in forum Car Parts For Sale
    Last Post: 26th June 2009, 07:16 PM
  3. FS AE86 turbo HOT HOT HOT!!!
    By 86 garage in forum Cars for Sale (Toyota Only)
    Last Post: 24th February 2008, 06:46 PM
  4. Unifilter Air filers, 4A-C Carb on 4A-GE manifold
    By asher in forum Car Parts For Sale
    Last Post: 15th June 2007, 08:16 AM
  5. Starting problems
    By eightsixboy in forum Technical - Questions
    Last Post: 25th May 2006, 10:34 PM
