Results 1 to 5 of 5
Thread: 20v main bearings
    Junior Member hau oi's Avatar
    Hau
    Cabramatta
    Default 20v main bearings
    hi im hau,
    i recently bought ACL race series main bearing for my BT 20v, but the only thing is they look very different
    mine on the( left) has a hole in it and a groove from one side to the other side, while the ACL one's dont.
    im guessing they are for oil feed to the crankshaft?
    have anyone come across this and confirm whether it could still be used or not?
Name:	minh bearing.jpeg
    Veteran Skylar's Avatar
    Ken
    Have you gone through the whole pack? The top 5 should be plain(for the bottom) and the others should have at least a hole for the oil to pass through and most likely a groove through it.
    The bearings that you pulled out of the motor should be the same, the one in the block should have a hole and maybe a groove, the ones on the main caps should be plain.
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    ok what you have and should have bought are half groove main bearings there should be 5 half shells with the half groove and five without the groove is there to supply the bigend bearings with a squirt of oil every half rotation of the crank
    now in race applications you can get full groove main brarings as i have put in my 7age so the bigends get a constant supply of oil all they do is supply you with 2 sets of the top shells there is only a few select 4a blocks that can handle these full groove main bearing sets late model big ports,smallports,20v,7afe just to name a few to
    to me in that pic they dont even look the same size do your new bearings even fit the caps if not then you are trying to fit bigend (conrod) bearings to your main caps but imo you will want full groove main bearings being that there will be a less chance that you will damage your bigends in high revving applications
    to answer your question NO DO NOT USE THEM if there is no groove then do not use them you will need at least half groove main bearings and the groove side goes on the block side the ungrovved goes on the bearing caps
    if you have problems i can help you out when i go back to work on the 10th pm me if you can wait i can supply you with full groove main bearings cheap
    the dyno pull to 300rwkw
    Hau
    Cabramatta
    so do anyone know the part number for ACL race series main bearing thats have the groove an the hole for ae111?
    Jun 2009
    Paul
    I am interested in this also. The correct oem Toyota part number for replacement bearings would be usefull too.
  1. Replies: 4
    Last Post: 26th September 2010, 08:14 PM
  2. rear main seal
    By sic86 in forum Cars or Parts Wanted
    Last Post: 13th October 2009, 01:17 AM
  3. main relays?
    Last Post: 23rd February 2009, 03:40 PM
  4. Main Fusible Link
    By tunney in forum Technical - Questions
    Last Post: 1st April 2006, 08:05 PM
