Results 1 to 10 of 11
Thread: hydro handbreak
    Senior Member bones's Avatar
    Apr 2010
    Brandon
    Geelong
    Default hydro handbreak
    probably a stupid question but can you run a hyrdo handbreak on drum rear of a ae86 , if so would it be worth it and is there a guide of how to do it?
    thanks
    Dec 2009
    Andrew
    California
    Nothern
    USA
    You could. It's exactly the same as doing one for calipers.
    Andrew
    Senior Member Stain's Avatar
    Derek
    Far North
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    ouch
    10 char
    Apr 2010
    Brandon
    Geelong
    lol^^ , does it work aswell ? anyone point me in the right direction of what i need and what to do thanks
    Veteran johl's Avatar
    Johl
    bascially you need to run the brake line that usually runs along your car to the diff, into the hydro handbrake and then the line will exit the handbrake and continue to the diff. in simple pulling the handbrake pushes the fluid to lock the rear brakes only as though you were using the brake pedal, it stumped me for a while until you think about how simple it is really
    Apr 2010
    Brandon
    Geelong
    aw yeah man good info thanks heaps, just relised im a fucking idiot and cant spell brake, ahwell
    Michael
    Crimebrook 2749
    would that only work becuase the front and rear brakes are on a different circuit yes??? (it doesnt put fronts on too)
    Johl
    yeh thats correct. the master splits into 2 lines from the master in the engine bay so the rear line goes into the master on the handbrake. so it does not affect the front brake line
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    do it i run one the best thing you can do for your rear tires to lock up
    the dyno pull to 300rwkw
  1. Isc hydro
    By sleeper_13 in forum Technical - Questions
    Last Post: 15th July 2012, 08:33 PM
  2. Corona Handbreak kit.
    By 4agejet in forum Cars or Parts Wanted
    Last Post: 6th December 2010, 08:30 PM
  3. how do ya tighten handbreak
    By Saikou in forum Technical - Questions
    Last Post: 7th August 2007, 09:35 PM
