Page 642 of 1886 FirstFirst ... 142 542 592 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 692 742 1142 1642 ... LastLast
Results 6,411 to 6,420 of 18860
Thread: Offtopic Thread 2011
  1. #6411
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    ok go and buy like 10 fuck off sized jackets and were them alll year, and see how much you sweat your balls off
  2. #6412
    Veteran biggo's Avatar
    Nick
    Noosa
    my balls sweat my man juice just fine thanks
  3. #6413
    Michael
    Crimebrook 2749
    hahahah your back
  4. #6414
    Veteran Jdm-Mcc's Avatar
    Jake
    Wagga Wagga
    Hey its biggo, hey biggo
  5. #6415
    Alex
    Wagga Wagga
    Stupid Nissans!!
    So my 180 wouldn't fire for the last 2 weeks. Was running fine, then suddenly decided to not start at all. Pulled each coil of 1 by one and checked that each plug had spark. Once spark was confirmed, I made sure there was fuel getting to the rail. Disconnected the fuel line where it connects to the rail and sure enough out comes fuel when the fuel pump primes. Still nothing...
    Anyway, only like an hour ago, I decided to turn the key, then bam, fucking thing started and idled fine. Revved it to around 4.5k after a minute of warming up, still no problems. Let it idle another minute then all of a sudden it just slowly lost revvs and died...Now it wont start again.
    I am so over it. Moving house soon, and have too much other shit to worry about. Worst thing is I have absolutely no idea at all on what the problem may be, and I have no idea where to start to find it.
    Have checked for spark multiple times, same with fuel to rail. I just don't know what else to do! Anyone had similar issues/can offer input
    Car is a 180sx with CA18DET for all you playing at home.
    Alex's 4AGTE KE70
    Or so was thought...
  6. #6416
    Jake
    Wagga Wagga
    How much did you pay for it again man?
  7. #6417
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    if its getting fuel, spark and air then its a wiring, sensor or ecu problem
  8. #6418
    Michael
    Crimebrook 2749
    please insert engine here
    check fuel pressure, again maybe your pump is packing it in (intermitting issue), i dont know much about ca's, check power at the pump also
  9. #6419
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    I had similar issues with a 4age.
    1. check all connections dealing with engine loom
    2. check injector pulse
    3. if no injector pulse, check power to ecu.
    if theres power to ecu but no pulse could be ecu isnt getting rpm signal (f'd cas or whatever they use)
  10. #6420
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    I'd put a dollar on it being CAS.
    Go to import wreckers, find CA18DET CAS, swap it in taking note of timing when you pull the dizzy out, will fire up like a beauty.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
  1. Offtopic thread 2011.
    By n2866 in forum Offtopic Discussions
    Last Post: 3rd January 2011, 09:40 PM
  2. Biggo's Offtopic Offtopic Thread
    By biggo in forum Offtopic Discussions
    Last Post: 14th July 2008, 09:19 PM
  3. offtopic thread
    By us_ae86 in forum Offtopic Discussions
    Last Post: 2nd August 2007, 01:03 PM
Tags for this Thread
