Results 1 to 4 of 4
Thread: Carb'd 4AGE on Hyperpak ignition no spark problem
    Dec 2010
    Default Carb'd 4AGE on Hyperpak ignition no spark problem
    Hi guys i have a bigport 4AGE engine from a AW11 MR2 on carbs with a Hyperpak ignition control unit to run the stock distributor.
    I am unable to get the engine to start due to no spark, well i say no spark i actually get one weak spark at the very first crank of the engine and then nothing at all when i continue to crank the engine. I dont always get the spark at the first crank of the engine either, its a bit intermittent.
    I have double checked the wiring against the diagram that came with the kit and the ignition coil is brand new. I'm at a loss with what is wrong with it, my only thoughts are that the distributor is causing my problems or the hyperpak unit itself.
    Are the distributors known to give ignition faults or are they fairly reliable?
    Any help with this would be most appreciated.
    May 2010
    Tyrone
    maybe a dud coil?
    I'm curious s to what the problem is anyway so please post up whatever it turns out to be =]
    Dec 2010
    Thanks bud for reply, i will check and report back.
    Someone else suggested to me that it may possibly be the hall sensor (not sure if thats the correct term for it) inside the distributor giving me my trouble as my symptoms were the same as what he had experienced with a couple of Volkswagens.
    Dec 2010
    Well i've had the Hyperpak unit tested and as i suspected its dud.
    At least i know what my problem is now.
  1. 4AGE Hyperpak Ignition Computer
    By Drift_725 in forum Cars or Parts Wanted
    Last Post: 8th December 2012, 10:45 PM
  2. 20v Waste Spark Ignition?
    By cpmorey86 in forum Technical - Questions
    Last Post: 17th May 2010, 11:17 AM
  3. ignition problem
    Last Post: 4th August 2009, 11:41 PM
  4. Ignition problems, Spark
    By grape_moosha in forum Technical - Questions
    Last Post: 14th April 2008, 02:33 PM
  5. Carbs, 4age carb manifold, jaycar ignition
    By quoccy in forum Car Parts For Sale
    Last Post: 19th June 2007, 10:50 PM
