Results 1 to 9 of 9
Thread: 4AGE dies under 3000 rpm
    Member grey_nomad's Avatar
    Henk
    Lake Gardens
    Default 4AGE dies under 3000 rpm
    Having problems with JDM 4AGE big port in AE86. Engine and ECU are from AA163 Celica as far as I know. Has been running fine since I fitted it back in 2005. Used as daily drive and track car.
    It has suddenly started spluttering when getting back on the throttle after lifting off, like when going through a round-about.
    Then it's impossible to get it off the line at less than 3000 rpm. Have to bring the revs up slowly or it dies.
    Fuel delivery is from Facet pump outside tank, VL pump in engine bay, both new.
    Code from ECU is 9, speed sensor - but this has always been there - no other codes.
    Any suggestions?
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    Faulty TPS sensor
    ~KEEP DRIFTING FUN~
    Henk
    Lake Gardens
    I should add that it only happens once the engine is fully warmed after a 20km drive.
    Veteran timbo's Avatar
    Tim?
    Wild West
    does it start up as normal, as in it's not a timing issue?
    Henk
    Lake Gardens
    Thanks guys for your suggestions.
    Starts up fine and runs normally until hot. Timing OK.
    Looks like you're right trikzlane. Appears to be a TPS problem. Voltage at ECU and TPS terminals has intermitent blips instead of smooth change. Checking resistance at TPS terminals confirms intermitent open circuit at more than 1 point.
    Temp sensor and MAP sensor seem OK.
    Where is best place to get new TPS?
    Engine is a JDM 4AGE.
    TPS Toyota Part No: 89452-20060
    PS. I'm in Ballarat Vic.
    Tim?
    Wild West
    you could try your local toyota dealership, i was lucky and got one new. only problem it was $200!
    another option is to change the whole throttle body as to use another TPS as they are not all interchangeable.
    i believe the part number you have quoted may also be found on a 22re out of a hilux...
    edit: found this as a possible reference:
    and ebay:
    Henk
    Lake Gardens
    Thanks timbo,
    Have purchased the TPS from eBay.
    Will let you know how that goes.
    Henk
    Lake Gardens
    Problem solved - was a clogged fuel return line from injector rail to tank. Engine was flooding.
    This was after I replaced a bunch of sensors that had no effect :-(
    Thanks guys for your help.
    Tim?
    Wild West
    haha bummer.. at least you have spares now.
  1. 16v 4AGE dies warm then won't start again
    By Brokenships in forum Technical - Questions
    Last Post: 3rd May 2012, 10:06 AM
  2. 4age dies when hitting 6000rpm
    By Alexii in forum Technical - Questions
    Last Post: 18th September 2010, 11:16 AM
  3. 4age dies when its hot
    By boh in forum Technical - Questions
    Last Post: 27th March 2008, 08:28 PM
  4. 4AC wont rev past 3000 RPM
    By Debeli_70 in forum Technical - Questions
    Last Post: 15th December 2007, 06:45 PM
  5. 4age farts and dies under throttle
    By Blood Child in forum Technical - Questions
    Last Post: 9th April 2007, 09:56 PM
