Results 1 to 6 of 6
Thread: Lift pump in fuel tank
    Senior Member TOFU's Avatar
    Terry
    Braybrook
    Default Lift pump in fuel tank
    Hi guys mite be a stupid question or mite not. If you have a lift pump at the bottom of your fuel tank and u have feel and electrical together is that a good mix. How do they put a electrical pump in a tin of fuel.
    TOFUTERRY
    Veteran johl's Avatar
    Johl
    all of the wires and connections are insulated so the fuel doesnt eat away at it
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I can take a picture of an intank pump I pulley out of an ST185 celica if that helps you.
    Damn car didn't have a drain plug in the tank wtf!?
    Terry
    Braybrook
    Can someone explain in basic language how this is done.
    This is what I no correct me if I'm wrong.
    First you have your lift pump which brings the fuel up out of the tank to the main pump (vl external pump) when then goes to the fuel filter and into your engine, then the unburnt fuel is returned back to the tank.
    How many pipes doesthe fuel tankhave I remember seeing 3 pipe coming out of the tank what's the third one for.
    What lift pump should I be getting and how to I wire the lift pump up so when I turn the care on it wont go up in flames.
    What happens if I add a surge tank is the unburnt fuel from the engine returned to that and the over filling of the surge tank returning to the fuel tank.
    Does any one have any photos or diagrams that may help me or explain to be now I can do the fuel system myself instead of paying 800$ for someone to do it forme
    Thanks heaps
    TOFUTERRY
    Endeavour Hills
    the third line is the breather, goes to the charcol canister in your engine bay.
    People have used the intank pump of the VL's before.
    Veteran Skylar's Avatar
    Ken
    easiest way is to buy a EFI tank out of a jap 4age car.
    otherwise, get an AE82 tank outlet and extend the pump bracket and wires to reach the bottom of AE86 tank. This will keep the system simpler with only one pump. If you feel like adding a surge tank run the AE82 pump straight into the surge tank then a vl external pump/044/whatever you feel like.
    Google spits useful stuff like this in less than a sec:
    and remember liquid gasolene doesn't burn only vapors. and even then you need an ignition source to light the vapors. The 12v in your tank isn't enough unless you're dumb enough to leave exposed wires inside the fuel tank that can short out and create enough heat/sparks.
  1. Replies: 2
    Last Post: 10th October 2011, 10:12 PM
  2. Jap ae86 fuel tank and lift pump
    By timpy in forum Cars or Parts Wanted
    Last Post: 19th April 2011, 11:36 PM
  3. Fuel system, surge, efi pump and lift pump
    By skin in forum Car Parts For Sale
    Last Post: 31st October 2010, 10:22 PM
  4. External fuel lift pump... Reccomendations?
    By Victim in forum Technical - Questions
    Last Post: 16th September 2010, 08:18 PM
  5. wtb: surge tank and lift pump
    By Brendo in forum Cars or Parts Wanted
    Last Post: 4th January 2007, 06:13 PM
