Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Installing Kelford cams and have some questions.
    Jun 2009
    Grant
    California
    San Jose
    USA
    Default Installing Kelford cams and have some questions.
    Hi folks,
    Happy new year!
    I am wanting to install some kelford cams, 194-B's into my blacktop 20v. I have a stand a lone so that part is covered.
    However, do I need to removed the head to take the valve spring retainers out? Would this tool work on a 20v?
    Any insight on the matter would be great. I'm wondering if I will have to order a new head gasket if the head comes off.
    Thanks!
    Grant
    Ok
    Seamus
    Milton
    Yes you can do it without removing the head, in exactly the same way as they're doing in that link
    And that TYPE of tool will work, but that EXACT one (the bluepoint one) is just a bit too big for a 20V head (i know, cause i have one). There are a few tools similar that are a bit narrower and should suit fine.
    Senior Member Stain's Avatar
    Derek
    Far North
    why do you want to take out the valve spring retainers when your installing new cams? I wouldn't bother changing em... to much hassle.
    i dont know anything about the kelford 194-b cams... do they require you to upgrade your springs, too?
    if you must change the springs, or you want to replace your seals for whatever reason,
    i'd recommend taking the head off the engine and doing it on a bench...
    so much easier than leaning into a engine bay for the entire job.
    Jun 2009
    Grant
    California
    San Jose
    USA
    What about removing the buckets? Any special tools needed for those? I need to adjust valve clearance when I set the cams in. The B's have 8.7 mm of valve lift, I am told the stock springs are OK. I don't plan on revving past 8500.
    Tell me if I'm missing something please.
    Dec 2009
    Andrew
    California
    Nothern
    USA
    The buckets? If you have the cams out use a magnet. It's quicker that way too.
    Bolt your new cam in, check clearances.
    Remove cam, change shims.
    Reassemble/dial in (if required/you have adj cam gears).
    Done.
    Andrew
    Moderator Sam-Q's Avatar
    Endeavour Hills
    magnet? I just use my fingers..
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    from memory 8.7 is too much lift for standard valve springs, i am pretty sure that's what i had in my car and that was getting coil bind with the standard springs.
    Andy
    Akio
    Mt Haruna
    Japan
    thats only on 16v andy, 20v's have near enough to 8mm lift factory so an extra 1mm isnt going to much of issue.
    Endeavour Hills
    this is something I plan to check in the next 2 weeks
    Jun 2009
    Grant
    California
    San Jose
    USA
    Catcams states that the springs bind at 9.5mm but I think I will want to pull a spring out and check it out in a vice and see how close it really is. Was really hoping to not have to buy anything else.
  1. well folks a few questions on 4age cams
    By akasod in forum Technical - Questions
    Last Post: 8th November 2011, 12:44 PM
  2. 20v st head, kelford cams, big port job, jun cam gears
    By 350hp4agte in forum Car Parts For Sale
    Last Post: 23rd October 2009, 09:16 PM
  3. cams questions
    By zookieboi in forum Technical - Questions
    Last Post: 7th August 2009, 10:47 AM
  4. questions about cams...
    By #109 in forum Technical - Questions
    Last Post: 1st August 2008, 11:16 AM
  5. Kelford Cams?
    By Dazed_Driver in forum Technical - Questions
    Last Post: 7th October 2007, 08:42 AM
