Results 1 to 10 of 11
Thread: Air from oil filler hole. Normal for 20V BT?
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    Default Air from oil filler hole. Normal for 20V BT?
    Hi guys,
    Can anyone with a 20V BT tell me if it's normal for a lot of air to be rushing out of the oil filler hole? I've done a compression test which was 190 across all cylinders, however it's eating oil. I'm hoping it's just the stem seals... however was surprised at how much air or potentially blowby (hopefully not) is coming out the oil filler.
    Cheers,
    Ves
    Check that your pcv valve isn't stuck... Thats the little grey thing on the cam covers...
    Pull it out and rattle it and you should hear the ball bearing move.
    Vesley
    Geelong
    I've checked the entire PCV system and all is well. The valve works fine, both inlet and outlet ports aren't clogged.
    Even with the PCV system unplugged with both ports venting to the atmosphere there is still a considerable amount of air rushing out the oil cap hole. I'm hoping this is normal for a 20V as they use shim under buckets and the buckets may act as mini pumps pushing air around the cam covers... fingers crossed.
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    all the 20v engines ive ever looked at (about 6) have done the same thing so im assuming its normal. i checked the PCV's on all of them too...
    Vesley
    Geelong
    Hmm... interesting. I'm guessing it must have to do with the bucket/valvetrain design moving a lot of air around. Cos I've checked my soarer and stagea and both don't even have the slightest hint of air from the filler hole. Could also be the PCV system. Maybe the other 2 engines were designed to have more vacuum (larger PCV valve) in the crankcase compared to the 20V.
    But it's such a relief that it's not blow by and all signs point to stem seals now.
    Filip
    Jozzaville
    the motor i have now is a very healthy ST20v that still does it yet i also had a blown ST20v that did it too..
    i cant figure it out.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the PCV's on 20V engines are undersized and just don't work well enough
    Filip
    Jozzaville
    I have a catch can setup with only half the pcv valve left (i chopped it) and it still does it.
    I might remove it completely and replace it with something..
    Dec 2010
    Cal
    I've seen this problem too. Beau Yates old bt20v turbo had a spring to hold it down.
    Senior Member Moebius's Avatar
    Christian
    I don't think it's a problem is it? Just a 4age personality trait.
  1. Oil around spark plug hole
    By Bozu in forum Technical - Questions
    Last Post: 20th August 2011, 01:53 AM
  2. Just installed Oil temp gauge. Whats normal?
    By maxhag in forum Technical - Questions
    Last Post: 23rd July 2011, 12:26 AM
  3. 4age oil filler cap metal
    By pen15 in forum Cars or Parts Wanted
    Last Post: 18th April 2011, 08:55 PM
  4. Normal oil pressure - 4agze???
    By v-tec in forum Technical - Questions
    Last Post: 11th September 2009, 07:48 PM
  5. tappet cover with oil fill hole
    By Rich_86 in forum Cars or Parts Wanted
    Last Post: 11th March 2008, 07:01 PM
