Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 37
Thread: best way to mount a oil cooler
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    Default best way to mount a oil cooler
    i was wondering what is the best way to mount an oil cooler.
    like this: (stolen from keimeir's build thread)
    but i was thinking half the cooler will go to waste as its covered by the bumper, but every one does it?
    i like the way motorfix have theirs across the grill on the cream wagon, as its fully exposed to the airflow.
    i would like to add one i'm i'm using is a simple tube and fin using the sstd fwdd smallport sandwhich plate(no thermostat) and the drain to the sump.
    all help appreciated.
    bursting ovaries since 92'
    Jun 2009
    Blake
    Penrith
    this is like how i was thinking, simmilar sized to mine, mines just not as wide.
    Jun 2009
    Blake
    Penrith
    and has anyone had aany oil peasure problems with using a oil cooler?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    you going to run thermastat so if only run to the cooler when the oil is actually hot???
    Mark
    if he's using the standard sandwich plate then as far as i know it has a pressure valve in it and only flows when a certain pressure is reached, so it doesn't flow all the time.
    I've got mine mounted the same as the top picture and i haven't had a problem in two years, though i haven't had a pressure or temp gauge on it.
    pretty sure that the ones on the other cars are rx7 coolers.
ID:	15446   Click image for larger version.
    Jun 2009
    Blake
    Penrith
    like this.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    isnt that just a spacer?
    Jun 2009
    Blake
    Penrith
    might copy yours cerby
    Mark
    cool, all i did was bolt a piece of flat across the radiator opening and then bolted a couple of bent aluminium flat onto that brace and the lower rad support then bolted the cooler to that. I did look at the rx7 coolers first but i got this other one cheap. to be honest if your not planning on going turbo later I would try and find a rx7 one cos i reckon they look the best
    Gone
    Joel
    Picton
    The only flaw in the setup is only half the core is getting direct airflow, the rest is not.
    The oil cooler works by "trapping" the relative airflow between the cores via the cooling fins and carrying away excess heat.
    if the airflow is blocked then the core really cant do its job because the air cant carry the heat away.
    Any cooling device needs to be mounted with direct or ducted airflow straight thru the core for maximum efficiency.
  1. Replies: 7
    Last Post: 28th July 2011, 07:48 PM
  2. Where to find 3SGE BEAMS Oil Cooler & Oil Filter Relocation Kit
    By 4A-G3 in forum Technical - Questions
    Last Post: 3rd February 2011, 12:12 AM
  3. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
  4. Oil Cooler and Sandy plate + remote Mount
    By RyGuy86 in forum Car Parts For Sale
    Last Post: 27th August 2007, 01:36 PM
