Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
Thread: best way to mount a oil cooler
  1. #11
    Veteran McLEVIN's Avatar
    Nov 2010
    in those motorfix cars they arn't running bumpers. what if they had bumpers on would those oil coolers effect the cooling of the radiator?
  2. #12
    Moderator Sam-Q's Avatar
    Endeavour Hills
    isnt that just a spacer?
  3. #13
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    i think it might be sam-q but if anyone knows of the sandwich plate i'm sure its you.
    standered on ae92 sx model with the small port 4age.
    bursting ovaries since 92'
  4. #14
    Mark
    yeah but in reality how efficient does it need to be?
    I mean Im running a cooler twice the size of the standard one, on a mostly standard motor, thats running a much larger radiator, in a much more open engine bay. Also where is the standard oil cooler mounted on an ae92?
    Yes a part of the air is cut off. Im sure i should really mount it a foot above the roof with a thermo fan that switches on whenever i get below 150 km/h.
    but i think people need to be a bit realistic. Half the people on here would say its not getting enough air flow so it won't cool enough, another half would say oh noes your not using a thermostatic sandwich plate so its going to cool to much, and the last half would say both those things in the same breath and then spontaneously combust.
    Personally I'm just going to say it's what the manufacturers did, its what a fair number of people who actually run them do, and its what worked for the last two years on my setup so why stress hahaha
  5. #15
    Jun 2009
    Blake
    Penrith
    but that picture is simmilar to what it looks like. i'll do more seaching for a better pic.
  6. #16
    Endeavour Hills
    yes I know the one, if i have it around I will take a pic. I like the look of the 5sfe heat exchanger myself
  7. #17
    Jun 2009
    Blake
    Penrith
    5sfe heat exchanger?
    can you post pics of both?
  8. #18
    Jun 2009
    Blake
    Penrith
    is that like a waater cooled one like on a subie?
  9. #19
    Endeavour Hills
    I will take some pics later if I can. It's completely different in the fact it's a water over oil heat exchanger. It's plumbed into place much like the heater core and should in theory not only make the oil heat up quicker but cool it when needed as well. I would assume when looking at it that it would only have a moderate cooling effect though.
  10. #20
    Endeavour Hills
    yes I think I remember seeing one of them when I was under the boss's WRX
  1. Replies: 7
    Last Post: 28th July 2011, 07:48 PM
  2. Where to find 3SGE BEAMS Oil Cooler & Oil Filter Relocation Kit
    By 4A-G3 in forum Technical - Questions
    Last Post: 3rd February 2011, 12:12 AM
  3. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
  4. Oil Cooler and Sandy plate + remote Mount
    By RyGuy86 in forum Car Parts For Sale
    Last Post: 27th August 2007, 01:36 PM
