So far:
Aus-spec AE86 Sprinter
Bottom End
7 rib 4AGE
Forged low compression pistons (Toyota 4AGZE)
Balanced conrods
Balanced stainless steel crankshaft (100kw)
Techno toy tuning overdrive crank pulley
Head
Ported and polished big port
HKS 272 degree intake and exhaust camshafts
HKS cam gears
HKS 2mm metal head gasket
Induction
HKS AE86 Supercharger kit
- supercharger has direct drive - ie no clutch like 4AGZE
T3 overdrive crank pulley (for more boost)
K & N pod filter
Fuel injection
Motec M4 ECU with wideband lambda and data logging
Sequential injection
4AGZE (365cc) injectors
Map sensored boost pressure
Air intake sensor
Water temperature sensor
Cooling
Oil cooler
China-spec52mm alloy radiator
Twin thermo fans
Exhaust
HKS Superheader II
2 in cat back
Drivetrain
Aus-spec T50
T18 tailshaft
Early/Zenki disc - disc rear
TRD 2 way LSD
4.77 final drive ratio
Suspension
Tokico HTS 102 adjustable dampers
TRD 8kg/mm coilover front springs
TRD 6kg.mm rear springs
Adjustable front lower control arms
T3 tension control rods
T3 adjustable upper and lower rear arms
T3 adjustable panhard rod
T3 traction brackets
T3 roll centre adjusters
Whiteline heavy duty adjustable front sway bar
Whiteline heavy duty adjustable rear sway bar
Urethane bushes elsewhere
Brakes
Standard discs rear
MA61 discs and calipers front
Goodrich braided brake lines
More to come.Will update with pics from time to time.
