What is the MR2 AW11 20v blktop(project car)? pics?
Located Gold Coast can post at your expense,
Contact alex on 0424 173 858,
don't count on me replying on here cause i dont have internets
CUSCO front coil springs 6KG - $100
CUSCO oil catch can (chrome) - $100
AE71 fuel tank with free fuel - $50
AE71 brake master cyl - $30
4AGZE smallport throttle body - $30
4AGZE smallport inlet manifold - $30
4AGE 20V ST with ECU/loom plus spare motor - $1500
4A crossmember - $50
ae86 LCA's - $30
ae86 rear swaybar - $30
ae86 rear swaybar with mounts - $75
garrett AiResearch T04 turbocharger with
16v manifold, HKS external wastegate,
dump pipe, screamer pipe - $900
celica whiteline rear swaybar (adapted to fit S1 Tseries)- $50
camry v6 radiator with inlet/outlet on same side for ae86 - $100
rwd water pump pulley - $50
W5x to 4A bellhousing - $500
ae86 caster rods $30
103mm SC12 supercharger pulley 13psi - $250
ae86 caster rods with mounts and front swaybar with mounts - $100
T-50 gearbox with jdm bh, mount, shifter, fork, bearing - $600
tailshaft t-50 to borg diff - $50
4AC coil - $10
4AC voltage reg - $30
ae86 brake calipers - $50
ae86 front hubs - $60
jdm washer bottle - $50
ae86 rolling shell with t-series rear diff no interior - $1200
MR2 AW11 20v blktop(project car) - $3000
thanks for looking.
call him up
whats the whiteline swaybar size? and is it adjustable?
AND post to 2166 nsw?
2nd dibs on sway bar, with post to NSW 2264.
longshot but do you have any blacktop quads?
update
