Results 1 to 3 of 3
Thread: about ecu problem
    Arthur
    Default about ecu problem
    Hi guy, some one breakin my car few days ago, they stolen my apexi safc controler from my car, so car car engine is not right now, it also engine check light keep light on the dash, my car is runing 4age bigport with superchage head, if I change back to stock bigport ecu, the car will be runing well or i still need returned it up?
    Ok
    Seamus
    Milton
    An SAFC requires that either the AFM or MAP sensor wire going into your ECU to be cut. With the controller itself missing, the ECU is getting nothing from the MAP/AFM wire. Being a pretty important (!!!) sensor, your ECU will be having a heart attack.
    I would just remove all of the SAFC wiring and reconnect the cut AFM/MAP wire. If your engine is fairly close to standard, then it should run fine.
    ^ Clicky clicky!
    Arthur
    Thanks 70XIN, but i am not good at mechanical, could u tell me where is AFM, MAP and ECU in the car? Thanks again
  1. Replies: 2
    Last Post: 19th March 2012, 01:24 PM
  2. ADL: 4age loom and ae86 Jap ecu and Aus ecu
    By rke_011 in forum Car Parts For Sale
    Last Post: 24th October 2011, 07:14 PM
  3. 4agze ae101 ecu and bigport ecu.
    By 86TRD in forum Car Parts For Sale
    Last Post: 4th April 2010, 07:07 PM
  4. ecu problem may be solved, please confirm or discuss
    By dr1ft-pig in forum Technical - Questions
    Last Post: 7th January 2009, 12:28 AM
  5. 4agze ignition/ecu problem
    By Andor in forum Technical - Questions
    Last Post: 3rd June 2008, 12:22 AM
