hey all, just picked up some 40mm dellorto twin sidedrafts for my smallport. i've decided that EFI is a bit boring and wanted to go with something that has a little more character.so i have the carbs, and i know i can get a manifold to bolt them to the motor from redline performance (). now i'm wondering, can anyone give me an exhaustive list of everything else i need to do this, especially my options for ignition?
Buy an ECU, something real simple with only one ignition output and tune the ignition that way. run an adaptronic or something if you want it fancy lookin' with coil on plug and all. or just let the stock ECU deal with the timing.
You can get a distributor from something that originally ran vacuum + centrifugal advance and try tuning it that way but woah!, too backwards for me.
