Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: need 300hp
    Member chacheen's Avatar
    Sep 2009
    charlie
    nsw
    narrawallee
    Default need 300hp
    hey guys ,i posted a thread about putting a s2k honda motor into my sprinter for gravel rallying but after reading the thread and all the talk about cutting crossmembers and affecting the front geometery i think its too much hassle.so my plan is to run in the historics or the new r2 2wd class in the ARC but i want to build a car with 300hp or more to have plenty of power to beat the huge $$$ escorts.is there a toyota engine out there that will give me the hp im looking for and be RELIABLE.
    Senior Member Hachi_Tom's Avatar
    Mar 2010
    Tom
    Ashmore
    you could build a 3sgte
    you havent stated how much of a budget you have so its anyones guess to what you could build...
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    First thing that pops into my mind is the 2jz-GTE from the supra, very good and tough in stock form and if I recall correctly also able the make a reliable 300hp with stock internals!
    Second thing that pops into my mind is how are you going to fit that in a sprinter...
    ADM AE86 Levin
    Sep 2009
    charlie
    nsw
    narrawallee
    i have a healthy budget (just sold my evo rally car) ....how much would a 3sgte cost to build ...what car is that out of i dont know engine codes....
    would a supra engine be really heavy i have to think of weight distrabution too.....i have already spoken to modena in melbourne and they are doing a sequential gearbox that will handle 300hp easy so just need engine suggestions and a rear axle too
    Gunner
    If you have the money to get a sequential box, you have the money to build a turbo 4A to make a reliable 300hp.
    Sep 2009
    charlie
    nsw
    narrawallee
    would prefer a n/a engine...i think a turbo rwd on gravel would be tough to drive ..if i wanted to have fun and just drift up the stage maybe but i want to win rallys with this car.
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    A solid 3sge beams motor would make 300hp NA, and is easier to fit into the sprinter than the F20C, Neil bates is building an RA40 celica for the same class (assuming this is for the new ARC 2wd grunter section)
    anything 6cyl would be too heavy.
    Andy
    Dave
    forget them all. especially the 2j....
    millington diamond.
    an engine designed for rally, n/a producing about 300hp. yes it will cost a bit, but thats how you get a reliable 300hp.
    real rally cars use millington diamonds!
    allows you to do something along these lines....
    edit: yes i know you said toyota engines, but i dont think its worth it. just get a wicked engine to start with.
    - Blaise Pascal
    Glenn
    North Ringwood
    my motors are making 190 kws at the back wheels, a std s2000 makes about 140 on the same dyno to give you an idea
    User fantapants's Avatar
    Pat
    karn dave.... spend the sort of coin on a beams that it would cost to get a millington, and you get a very competitive engine.
    fwiw,
    a copy of glenns system which is over 300hp would be in that ballpark, but i would go drysump for clearance and safety of the engine as to keep the engine low your sump would be very low.... with dry you could get the engine low enough for zero tunnell mods even with the 6 speed and still be very safely behind a sump guard.
    im not sure if he is on here, but there is lad in wa who races an 86 in rally, maybe have a chat with him? gets around with username mc86? i think?
    glenn is celicara45 on here and would the most useful source of realworld prices and information.
    as you can tell the rest of us are mainly good at spending other peoples money
    ps what sequential you going with?
    06/07/2011
  1. Bosch 070 fuel pump (300hp)
    By kaibeecee in forum Car Parts For Sale
    Last Post: 5th February 2011, 10:06 AM
  2. 300hp hachi bt20v
    By HACHI - 6X in forum Offtopic Discussions
    Last Post: 7th September 2010, 12:05 AM
  3. Team Fine 300hp 4AGTE AE86 Trueno
    By PeakingDuck in forum Offtopic Discussions
    Last Post: 25th December 2009, 01:04 PM
